Old 03-23-2014, 08:47 PM
lake weir skier lake weir skier is offline
Boat: 1994 MasterCraft ProStar 190, 350 TBI, 1:1
my '95 has this wire and it is connected to the metal fuel fill assembly - which inserts into a rubber fuel filler hose... so based on this I should disconnect.
Well, that is what I'm trying to figure out for my 1994 boat. My reading of the technical service bulletin was the official recommendation was to NOT disconnect if you have a metallic fill, which mine appears to be. The technical service bulletin quoted at the link above makes reference to a plastic fill by Perko. I went on Perko's website and found a fill that clearly has a plastic neck, for lack of a better term, but mine looks metallic. The Perko installation instructions say not to use a ground wire on that plastic design, but my design looks different. I'm going to call Mastercraft and see what they have to say.
1994 ProStar 190, 350 TBI, 1:1
Old 03-23-2014, 08:55 PM
Table Rocker's Avatar
Our pre '99 boats have metal fills. The service bulletin states:
However, please note that this directive applies only to PLAS-TIC fuel fill assemblies with metallic caps and retaining chains; the U.S. Coast Guard and ABYC standards still require that any ALL-METALLIC fuel fills continue to be bonded.
MasterCraft knows what fuel fills were used on our boats and made the change for '99 forward.
Our pre-'99 boats (having metal filler necks) should continue to have the filler neck bonded to the boats ground bonding system.
'96 ProStar 205 SD LT-1
Old 03-23-2014, 08:57 PM
thanks Rocker..
Old 03-24-2014, 10:59 PM
I called Mastercraft today about this issue. They said they have put out nothing additional on this issue since the 2005 technical service bulletin referenced above.
Old 03-26-2014, 06:47 AM
Traxx822's Avatar
Traxx822 Traxx822 is offline
Mike, no reason to remove a perfectly good bonding wire. You have a metal kneck just like mine? If so then leave it.
Sent from my HTC One using Tapatalk
1 Corinthians Chapter 13 - 11
