Old 03-23-2014, 04:23 AM
lake weir skier lake weir skier is offline
Boat: 1994 MasterCraft ProStar 190, 350 TBI, 1:1
Wiring WEMA fuel sender
The instructions for installing a WEMA fuel sender say the pink wire should be connected to ground, which my multimeter thinks is the black lead from the boat based on checking for continuity to the main grounding point on the engine block on my 1994 ProStar 190.
I want to make sure Iím not missing anything important before reversing the colors in connecting these wires. Have others installing a WEMA fuel sender on a circa 1994 boat found they needed to connect the black lead from the sender to the pink lead from the boat and the pink lead from the sender to the black lead from the boat?
1994 ProStar 190, 350 TBI, 1:1
Old 03-23-2014, 11:32 AM
mtajpa's Avatar
mtajpa mtajpa is offline
Generally the pink wire would go to the gauge and the black wire to the ground system on a two wire system. Doesn't really matter as it is just an adjustable resistor. Link is to a standard marine color code for wiring. Pink is described from sender to gauge.
http://www.jamestowndistributors.com...nt.do?docId=80
99 MariStar 230 Sport LTR 330
Old 03-23-2014, 11:41 AM
Table Rocker's Avatar
From the WEMA website, it appears the black lead from the sender feeds the gauge.
http://www.wemausa.com/faq/#.Uy7xeFwXWMM
Q: How does the 2 wires from the senders connect?
Black wire connects to the gauge; pink wire connects to the ground. The sender draws power through the gauge connection.
It seems a bit backwards to me. In the DC world, black is usually to ground.
'96 ProStar 205 SD LT-1
Old 03-23-2014, 11:53 AM
mtajpa's Avatar
Saw that on their site. Must be true if its on the internet.
Old 03-23-2014, 11:57 AM
mtajpa's Avatar
He is a thread I created for a 2 wire sender the PINK wire from my sender goes to the gauge.
http://www.mastercraft.com/teamtalk/...ad.php?t=48823
