Old 03-13-2014, 02:23 PM
TresRiver205's Avatar
TresRiver205 TresRiver205 is offline
Boat: 95 Prostar 205
1995 ProStar 205 Backseat Rebuild
When I bought my project boat the backseat was basically a broken styrofoam base, vinyl cover and the foam back. This winter I decided to build a new frame and reconstruct the seat.
Figured I'd post the results in case anyone else ends up in the spot I was in.
Old 03-13-2014, 02:47 PM
TN Skier TN Skier is offline
Boat: 1992 Mastercraft Prostar 190
Nicely Done! Any pic of it installed back in the boat?
Old 03-13-2014, 03:06 PM
Ben Ben is offline
Boat: '94 PS205 LT1
I'm gonna go with this wasn't your first woodworking project. Looks good. I like the fact you can slide stuff under it.
Old 03-13-2014, 06:03 PM
Here's one, sorry about the quality. Garage lighting + phone camera makes for mediocre pictures.
Old 04-01-2014, 09:12 PM
scottlippman scottlippman is offline
Boat: MasterCraft PS 205, 93' 351
This looks excellent. 1. How much does it weigh? 2. I like how you can slide things underneath but wonder how strong the center seat section is with no support. Seems even 3/4 plywood will sag given enough time. 3. It appears the upholstery is the original (as indicated by the 'Star). Was the original simply in good enough shape to use again? Again...nice work.
Old 04-02-2014, 12:05 AM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
Looks good! I would assume that you really don't plan on removing it too often.
Old 04-02-2014, 02:43 PM
I haven't weighed it but I'd guess it's around 60 lbs. It takes two to get it in and out but more because it's bulky than heavy.
There is a support in the middle, I just located it back a bit so it doesn't stick out. Definitely need a middle support.
The original upholstery was complete and a bit faded but solid. Thanks goodness. I had to build a new seat bottom for my drivers seat and I struggled to get the vinyl sewn right for that simple shape. $1000 for getting new skins sewn seems a lot more reasonable to me now.
Thanks.
Old 04-08-2014, 07:21 PM
John 3:16-18
Old 06-05-2015, 02:57 PM
woodskier woodskier is offline
Boat: 1984 Stars and Stripes, PCM 351, power slot
Fantastic- Where did you get the styrofoam? (assuming you used some) Ants got into my recondidtion rear seat and destroyed about to feet in the middle of the seat. Trying to get the correct styrofoam to repair
Thanks in advance; You can see my 84 SD&S on earlir posts
Old 08-03-2017, 06:21 PM
jieiku jieiku is offline
Boat: 1986 Mastercraft Skier P-S 351w
great pictures showing the framework, I think this will be helpful with rebuilding my backseat. Like you I have some pretty good vinyl, but the styrofoam is very beat up, and the wood strips that were glued to the styrofoam rotted, so all i really got is some so so styrofoam and a completely remove vinyl.
