Old 03-03-2014, 11:05 PM
adrenalinteufel's Avatar
adrenalinteufel adrenalinteufel is offline
Boat: mastercraft x2 2004
2004 x2 fuel pump
the pump on my x2 has burnt out and i was looking for an aftermarket replacement. I have seen many on here but none that specifically say they can replace the mastercraft pump P/N 155183 (which has since been replaced by the 155208) anyone have any experience with this?
Old 03-04-2014, 05:50 AM
Boat: No Boat
What motor do you have?
http://www.mastercraft.com/teamtalk/showthread.php?t=25783
http://www.mastercraft.com/teamtalk/...ad.php?t=24965
http://www.mastercraft.com/teamtalk/...ad.php?t=53764
Tim
Old 03-04-2014, 09:53 PM
Indmar mcx 350
Old 03-05-2014, 06:17 AM
Boat: No Boat
Well, if you want to replace the pump itself and not the entire unit you could use either of these. I pick up the AC Delco from Napa for $70ish and just keep it in my boat.
These are replacement pumps for the in tank pumps.
AC Delco ep356
Advance Auto Parts E2044
The fuel pressure on your boat should be between 55 and 62 psi from idle to WOT.
Use the first link in my other post for a how-to.
Lots of TT users have replaced the in tank pumps with these after market parts.
Tim
Old 03-05-2014, 10:58 PM
Repeat thanks for all the help, I've been scouring the posts for a pn to replace it. I'll be at napa in the morning. Be ready for me to be seeking more wisdom.
Old 03-05-2014, 11:21 PM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
I will keep an eye on this, as I may have to do the same thing. Mine will not go past about 3/4 throttle without surging. I haven't tried the fuel pressure gauge just yet, but I plan to once I get the boat in the water this Spring.
Old 03-06-2014, 12:44 PM
Boat: No Boat
There are how-tos already posted for pump replacement on here.
I would suggest testing your fuel pressure before you do the pump.
If you don't get a chance to check the pressure before we get up to Martin I'll bring my gauge with me. But I'm not sure if your boat has the schrader valve on the fuel line from the factory or not.
Tim
Old 03-06-2014, 04:40 PM
The mcx does have a schrader on the line
Old 03-06-2014, 04:43 PM
Boat: No Boat
Yeah, I know the MCX does. I was referring to my fellow Alabamian with his predator.
Tim
Old 03-06-2014, 09:13 PM
A stop at advance auto, an hour in the tank and a shot of starting fluid later it fired right up! Thanks for the help. I am showing only 48 psi though, is this something that will clear up once I get it in the water and run some fresh gas through it?
