Old 03-15-2014, 02:28 AM
maryyy
. But regardless I am going to need to purchase all three of these parts and have them replaced and possibly the prop shaft. I have all of the part numbers minus the prop shaft so my question is where would be the best place to purchase these parts from.
Old 03-15-2014, 10:31 AM
snork snork is offline
Boat: 07 xstar
from your local Mastercraft dealer
Old 03-15-2014, 12:22 PM
www.Skidim.com should have them all too.
Old 03-16-2014, 09:54 PM
MC225 94 MC225 94 is offline
Boat: Mastercraft Maristar 225 VRS 1994 5.7L
How is the gel coat around the rudder as it enter hull? any spider cracking or worse? Also inspect gel coat at union where strut meets hull - most likely okay if minor strike - if prop and shaft took brunt of it.
There is spider cracking around the rudder port and am not sure exactly how bad it will be once i get the housing out of there. There is two knicks through the gel coat and into the fiberglass where the prop got pushed up into the bottom of the boat. Hoping where the rudder goes into the hull is not badly damaged. Will find out soon and post pictures
prop, prop shaft, rudder, rudder shaft, strut
