Old 02-19-2014, 10:38 AM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
Every carbureted Ford I own runs a 143 degree thermostat. All run at 160 +/- on the temp gauge.
PCM EFI Fords specify the 160 stat, and the engines run closer to 180 on the gauge.
I dont know if Indmar is different, but I suspect not.
Old 02-19-2014, 03:14 PM
Tristarboarder's Avatar
Boat: 2002 Xstar
When I called skidim, they specifically told me that the 351W can take either T-stat, but the 160 was the recommended choice because it's helps in the atomizing of the fuel, resulting in more efficient furl burn and more consistent performance. I went with the 160, and my temp gauge never gets over 150 and the engine runs great. I went with the opinion of the people in the know....
Old 02-19-2014, 03:53 PM
DooSPX's Avatar
DooSPX DooSPX is offline
Not to discredit anyone from DIM, because I buy from them and have spoken with their staff and was impressed for the most part. But, I'm not sure I buy the "better performance from better fuel burn" bit. Only reason modern engines in cars run at 220 is for emissions. Nothing about performance. Also, if your temp is actually around 150, the T-Stat is more then likely not even open. The much lower T-Stat in boats are because the motors are at a constant high RPM with HUGE amounts of load compared to a automobile.
When my boat is up to temp it's either right at 143 or so (T-Stat open) or right at 150 in the hottest water.
A.K.A. One of a kind mistake
2011 Best In Show- 1987-2000 class
Trying to keep slalom alive
Need a new prop to fit your needs? Call Eric from OJ PROPS 800-359-9730
Old 02-19-2014, 03:54 PM
Razzys Wagon Razzys Wagon is offline
Boat: 1987 pro star 190
My '87 ps190 has the indmar 351 and it runs 120+/- while cruising and 160-180 idling..... sounds like I'm stuck open or non-existant....
Old 02-19-2014, 03:55 PM
DooSPX's Avatar
I do think you will be fine either way. The most important part is just being on the water enjoying your boat!
Old 02-19-2014, 03:58 PM
DooSPX's Avatar
what is your water temp? How is the raw water impeller? My factory buzzer comes on around 190. (Now light, after I wired in a light to my buzzer cause I can't hear the darned thing while running)
Old 02-19-2014, 04:29 PM
New impeller was the same as old one, it has been that way since i have owned it. 2 years now. I did replace the impeller middle of last summer, but it is still the same.
After pulling my kids for an hour or so and I stop and idle it will creep up in that range for a few minutes then ease back down.....on the fake lake it won't get over 110 on the guage.....
Old 02-19-2014, 04:30 PM
I'm thinking stuck open or not there.....
Old 02-19-2014, 04:34 PM
If it's open or not there, you will not likely get to 160 idling unless there are pieces of impeller clogging up water flow. I forgot to put my impeller in last spring and it ran pretty cold all the time..........then I figured it out.
Old 02-19-2014, 04:40 PM
John 3:16-18
