Old 02-05-2014, 09:19 PM
ttu's Avatar
ttu ttu is offline
ventless fireplace logs
well since almost all of us are in a deep cold what does anyone know about ventless fire place logs. I currently have a gas fireplace with a flu.
thinking about upgrading the logs to ventless for more heat. any input?
Old 02-06-2014, 08:00 AM
JohnE's Avatar
JohnE JohnE is offline
Boat: XT22
I don't think they put out more heat and they are dangerous.
Old 02-06-2014, 09:07 AM
pap pap is offline
Ventless puts a huge amount of moisture into your home. Safety wise they have low oxygen cut-off, so I don't think that's a huge deal anymore. But I wouldn't (and didn't) buy them.
We installed a nice sealed unit with outside venting. It doesn't suck air from the house (it brings in outside air for combustion and vents externally through a single double-walled vent), puts out a huge amount of heat, and keeps the house sealed.
Old 02-06-2014, 10:16 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
We have had ventless for years. Like you, we have a flu and on the recommendation of the plumber who hooked up the fireplace, we leave it open slightly. The advantage of more heat is nice at the cost of looking slightly less realistic than vented logs. I have never encountered any issues with moisture. YMMV.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 02-06-2014, 11:21 AM
pap pap is offline
IF you leave a flue open, it's no longer ventless
Old 02-06-2014, 12:33 PM
tph's Avatar
tph tph is offline
Vented vs. Ventless
How does a ventless system work. It seems like the product of combustion would be released into your home. I converted to vented logs this past year and I even have problems from time to time when the flu is cold or there is a backdraft.
Old 02-06-2014, 01:17 PM
ahhudgins's Avatar
Boat: 79 S&S. 87 Prostar Powerslot. Present 95 Maristar 200VRS
I had no fireplace in my house or the lake house so I installed ventless logs in both over ten years ago. Gas logs are no more dangerous than a wood burning fireplace (less IMO) and 100% of the heat from ventless logs goes into the house. I plan to get a second set of gas logs for the lake house when the price comes down in the spring.
Old 02-06-2014, 01:19 PM
aquaman's Avatar
aquaman aquaman is offline
Boat: 93 Barefoot 200 Yamaha 225F
Just remodeled and changed to ventless fireplace.
I thought I would not like it......but it puts out about 3x the heat of the vented variety and; the fakey logs are pretty convincing.
Texans are probably not the most knowledgeable fireplace consultants, we use them mainly for decoration.
Old 02-06-2014, 02:04 PM
etduc's Avatar
etduc etduc is offline
Boat: Something else, DD 2004 red/white/black
There is no such thing, as "ventless." It is just venting in a different way.
In an existing fireplace (masonary/metal) it'll vent past a closed leaky damper. In Eastie's case, plumber suggest leaving damper slightly open. Hello, vented!
In loosely built homes, vented thru the cracks, windows,ceilings, existing duct, doors, etc. Hello, vented! You tighten up these areas, you could have moisture related issues. (health/home repair) It is well documented, in the hvac world.
An old school masonary/metal woodburning fireplace, burning oak, produces about 100,000 btuh of heat. The chimney, is designed for that much heat vented material/burnt fuel. A set of 20" gas logs, used in that same fireplace, produces about 40,000 buth of heat. With flue open, you will feel cold air, fall out the fireplace. You have to reduce the damper opening, to reduce the draftiness. (Most gas log sets, include a clamp thingie, to make this adjustment.)
NOTE: btuh difference. Efficiency is actually about the same. About 50% So oak, puts out twice the heat, but also needs about twice the fresh make-up air, to function. Not talking about enclosed gas fireplace/stove system, that's a different thing.
Been awhile, since I sold any gas hearth systems, or log sets.
My company policy, is we never recommend or install ventless gas logs.
Everything has a trade off.
Ayyyy!
2004 Red/White/Black something or other.
Formally, 1994 RED Mastercraft 205, Chevy 5.7 TBI.
Old 02-06-2014, 02:12 PM
ttu's Avatar
ttu ttu is offline
thank you everyone for the input. i guess that is why they are illegal in a few states.
