Old 02-04-2014, 12:13 AM
treiter's Avatar
treiter treiter is offline
Boat: 2009 X-15
09 X15 Ballast Pump Issue
Started through my list of things to fix from last season. On that list is the port ballast pump. When filling it will sometimes kick out and the switch will flash. A quick reversal and it will fill again but shortly after trip again. This will go on until filled. Last winter I replaced all the impellers with new green ones. Suggestions on where to start looking? I was thinking I should remove the impeller and turn it on to see if it will time out. Emptying is no problem. Bearing? But why one direction only?
Old 02-04-2014, 01:23 AM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
do you remember the flashing interval on the switch?
-Aric
LONE STAR MASTERBASH 2018
Details released 12/17!!!!
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
1985 S&S- For Sale
Old 02-04-2014, 10:28 AM
treiter's Avatar
Boat: 2009 X-15
Believe it was a constant rapid flash. It happens way before the timer should finish.
Old 02-04-2014, 12:39 PM
MC25's Avatar
This used to happen to me also. Is it happening just at idle or also when you're driving?
-Aric
1985 S&S- For Sale
Old 02-04-2014, 01:03 PM
treiter's Avatar
Boat: 2009 X-15
When at idling at high rpm while filling.
Old 02-04-2014, 04:53 PM
MC25's Avatar
Hmm.. rules out the voltage issue. My ballast impellers were fine but the center part was stripped out causing it to spin and then stop, have you pulled them and inspected the impellers?
-Aric
1985 S&S- For Sale
Old 02-04-2014, 06:26 PM
treiter's Avatar
Boat: 2009 X-15
Just installed last year but I will definitely be pulling them and having a look. It's weird no breaker trip or anything. Might have to call Jason at Wakemakers for help.
Old 02-04-2014, 06:36 PM
potsie potsie is offline
Boat: x15 2008
Switch port to starboard and that can rule out the motor or confirm pump motor
Old 02-04-2014, 06:44 PM
blackhawk's Avatar
Boat: 2006 X15 350 MCX
treiter - Swap them like Postie mentions. If it does follow the motor, it is odd that you would only see a problem in one direction. Only two things that I could think of, if it is the motor. 1) flat on the impeller has gotten stripped where it only catches in one direction 2) could have a bad motor brush that is hanging up in one direction only.
We defy the mafia!
Old 02-04-2014, 06:56 PM
treiter's Avatar
Boat: 2009 X-15
Thanks guys. Now that I think about it those pumps are still factory upside down. I'll swap them and fix the orientation while I'm at it.
