Old 02-01-2014, 02:53 PM
Footin's Avatar
Footin Footin is offline
Boat: 2007 Maristar 200VRS X2
Ballast System Install
I have started the ballast system install on my 2007 200VRS and I thought I would share in case anyone else was pondering the idea:
I started by ordering a set of factory gauges and breaker/relay box from Great Lakes Skipper. This was new and was slated for a 2006 230. I wanted this set up for two reasons, 1. No timers and 2. I would look fairly factory.
Here is a picture of what came with it. The gauges/switch panel, wiring harness and relay/breaker box.
OH-IO!
Old 02-01-2014, 02:56 PM
Footin's Avatar
I started last night by installing the gauge/switch panel, running all the wires, extending the battery harness, mounting the relay/breaker box and picking fiberglass splinters out of my hands and arms.
Here is what the area next to the dash looked like before:
OH-IO!
Old 02-01-2014, 02:57 PM
Footin's Avatar
And with the panel installed:
OH-IO!
Old 02-01-2014, 02:58 PM
Footin's Avatar
I mounted the relay/breaker box in the port locker on the back of the seat. This is where some of the factory models put it and it worked the best with the harness I had:
OH-IO!
Old 02-01-2014, 02:59 PM
Footin's Avatar
Harness wiring ready to connect to the pumps in the factory locations on the transom.
OH-IO!
Old 02-01-2014, 03:04 PM
Footin's Avatar
That's about all I can do until the rest of my stuff gets here. I placed a nice order with Wake Makers yesterday:
750 Sacs for the rear compartments
690 X2 Sac for under the bow seats
3 Johnson pumps
3 thru hulls and ball valves
3 vents
65 feet of 1" ballast hose
BTW: WakeMakers are AWESOME to deal with!
OH-IO!
Old 02-01-2014, 04:00 PM
rek's Avatar
rek rek is offline
Boat: Mastercraft X9 - 2003
Sweet will be following this thread!
Old 02-01-2014, 04:04 PM
TOO-TALL's Avatar
TOO-TALL TOO-TALL is offline
Boat: Mastercraft X2 2003 mcx
Awesome.....looks good so far
---Animal house
Old 02-01-2014, 05:37 PM
Boat: No Boat
Did you order some deutsch connector to the pump leads and run to your pumps?
I have the connectors and the $200 pliers for the ends. If you want I can make you three pigtails and send them to you. In return just send the the female deutsch connectors and the green inserts. I have a bunch of the leads.
You'd still end up either soldering the leads or using but connectors. I know the leads on the pumps aren't normally long enough to just put the deutsch connector on the pump leads.
Tim
Old 02-01-2014, 05:46 PM
Footin's Avatar
Thanks for the offer, I will let you know as I have not decided what to do yet, I do have weatherproof spade crimp connectors I could use.....just have not decided yet.
Someone told me you can install the deutsch connecters with a punch and not use the $200 tool? The only pump that will need wire added to the harness is the starboard one, the other two have long enough leads.
OH-IO!
