Old 01-28-2014, 10:46 PM
lukedeuce's Avatar
lukedeuce lukedeuce is offline
Boat: 1983 Stars and Strips
Trailer Wiring and Ideas
As I am compiling a list of things needed to redo the wiring on the trailer and fixing side markers, I contemplated doing some minor upgrades to the main connector. With the new to me Dodge truck, the four flat is located next to the license plate - an extra 12-18" where my last truck's pig tail was located. I had originally thought of just extending the whip on the trailer side and wrapping in a protective sheathing, but think this may look like an after thought.
After looking at different products, I am now leaning towards using a 4 ft flex coil that has the 4 flat on one end and whip on the other end so i can take off from there with the trailer wiring. A couple dilemmas with this...no good way to make a solid mounting point on the trailer and it may not look the way I am after...
Maybe a mounting bracket under the tongue right before the wiring enters the trailer/conduit and i can place the male plug there and utilize a male to female flex coil to make the connection from truck to trailer
The flex would always need to stay with the trailer, if we were to ever sell. But I think that would be OK as it is a minimal cost.
I like the idea of using a flex coil as when I back the boat into the garage, the angle gets pretty tight and i always worry about over extending the wires.
anyone out there have any ideas or new products i haven't stumbled across yet?
here are some pictures of parts noted above:
bracket
Name:  4 flat bracket.jpg
flex coil
Old 01-29-2014, 01:03 AM
Sodar's Avatar
Sodar Sodar is offline
Boat: '07 ProStar 197 w/ MCX
You can do it a couple ways. I always like installing a plug on the side of the trailer for a cleaner look. It also lets you take the coil off to avoid damage or theft.
You can also use a pigtail like you explained. I just did this on my buddy's boat for him. Just use a cushioned wire clamp on the bottom of the trailer with a bolt through the frame to support the cable.
Jetconnex makes everything you need, no matter what way you go. www.jetconnex.com
-Cameron
2007 ProStar 197
1996 ProStar 190
Old 01-29-2014, 01:29 AM
wow that looks clean...
Old 01-29-2014, 09:21 AM
lukedeuce's Avatar
The plug on the trailer is what I would love to do, but this year trailer only requires a four flat. I don't have a spot on my trailer that I can put a recessed plug as it's an open c channel. The one spot I could do a recessed mount is too far back on the trailer and I would end up needing a flex that is too long
Thanks for that website, I hadn't seen that one yet and they have good prices
