Old 02-14-2014, 12:09 AM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
Removing exhaust hose
I have loosened up the exhaust hose clamps and have popped them loose from the muffler and exhaust tips. My problem is that I cannot pull the hose down far enough to get over the end of either the muffler or the tips. I am guessing that I may have to pull the tips off first, as I have to do that anyway and remember reading about heating it up and using a piano wire. I tried some fishing line but the tip is so tight on the transom, I couldn't get between it and the tip. If I could get the hose off, then I could push that from the inside out, but I can't get the hose off. BTW, the hoses are in a 90 degree angle and fairly stiff, so I can only move them maybe a half inch at most and I probably need to go 3" or so.
I was thinking this would be fairly straight forward, but it is not as easy as I thought.
Old 02-14-2014, 09:11 AM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
Dumb question, but do they need to come out in one piece? Why are you pulling your exhaust hose?
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 02-14-2014, 10:53 AM
Laurel_Lake_Skier's Avatar
Laurel_Lake_Skier Laurel_Lake_Skier is offline
Boat: 1996 FlightCraft
I had the same issue a year ago when I pulled mine to put stainless tips on. You'll need to get pretty aggressive with the hoses and they will eventually pop loose. Taking out the rear seat and floor panel all the way back along will be necessary - but you've likely already done that if you have the clamps off both ends. Then just make sure the hoses are not attached to anything (hold down brackets, zip tied to vent hoses, fuel lines or wiring) and pull on the exhaust hose while cranking them back and forth/up and down. Brace yourself so you don't fall backwards when they finally break free.
1996 FlightCraft Barefooter—Merc 200 EFI
1991 ProStar 190—Acme 475, GT40-P heads, Edelbrock Performer intake, Mallory YLM Ignition
(SOLD!)
The world is full of youth—what we need is a fountain of smart!
Old 02-15-2014, 04:01 PM
CC2MC's Avatar
Boat: 2005 x-10
That is not a dumb question. Ultimately, I would like to remove my exhaust tips because the gelcoat is cracked where the screw holes come into the transom. I need to remove the exhaust flanges in order to repair the cracked gelcoat.
Thanks Laurel for the advice. I will just have to put a little bit more weight into it I guess. How did you end up getting the old exhaust flanges off? Also, where did you get the new stainless tips?
Old 02-15-2014, 10:12 PM
Once the hoses were off, the original flanges came of fairly easily. I took the screws out, got a thin flexible blade of a putty knife worked in between the hull and the flange and then a bit of twisting and wiggling of the flange. Both came out pretty quickly. I spent a lot more time cleaning off the old sealant than getting the original tips off/out.
The new stainless tips came from an area MasterCraft dealer and were new-old-stock. I don't recall the exact cost but remember they were a pretty good deal....as I recall about $150 for the pair — they were exact matches for the original units.
(SOLD!)
Old 02-15-2014, 10:41 PM
CC2MC's Avatar
Boat: 2005 x-10
That is what I thought would be the case. I was planning on trying the same way of removing the flanges. I really have not thought too much about getting the adhesive off, but that is a very good point. If it is 5200, which it more than likely is, that will be a pain to remove. While I would like to upgrade to the stainless tips. I don't want to put the extra money into them. I will replace them with the same plastic ones that are already there.
