Old 01-15-2014, 11:26 AM
kgrove kgrove is offline
Boat: 2011 X-25
Not filling or emptying
One of my ballast tanks neither fills or empties. At first I assumed it was a bad pump or impeller, but I took the cover off and the impeller is in great condition and spins fine. If the sensor is correct, the tank is about half full but won't fill up or empty when the pump is working. The others all work fine (though maybe the stream is a little weak, so I think my boat could have prostrate problems).
Options I have considered:
Pump not priming - major leak in tubes for that pump? How would I find this? Other causes?
Blockage in tubes for that pump - how would I find this or teat for it?
Other ideas?
2011 X-25 with stock ballast system by the way.
Old 01-15-2014, 11:37 AM
76S&S's Avatar
76S&S 76S&S is offline
Boat: 2002 X Star
Try emptying the ballast with the boat on the trailer to verify that the pump is working correctly. I'm assuming your through hull is below the water line. If the pump is working then it's the gauge or sensor/sender. If not, try a new impeller first. They can look fine but still not work.
2002 X Star
Sold - 76 S&S
Old 01-15-2014, 02:24 PM
Boat: 2011 X-25
It does not empty on the trailer. When inspecting the impeller, all vanes were intact and in perfect condition and the impeller spins when powered on, it just doesn't suck any water. I'm thinking either their is an air leak somewhere so the pump can never generate any head pressure or there is a blockage in a line. I may try swapping impellers with one of the pumps I know is working and see if that changes anything (doubt it since the impeller looked brand new).
Old 01-15-2014, 02:26 PM
Boat: 2014 X-25 6.2 Ilmore
Disconnect one side of the bag and lift it upwhile emptying to prime the pump. The pump might just be scavaging for some reason.
Old 01-15-2014, 02:28 PM
Oh sorry didn't see you had hard tanks. It sounds like the pumps are just not priming for some reason.
Old 01-15-2014, 02:58 PM
Boat: No Boat
Sometimes, the ballast motor will run while dry but are so worn they just make noise and do not pump water when under load. IE when they have water coming at them. They are making noise but not really turning.
I've seen this happen more often on pumps that are mounted with the impeller side up. They start to leak water into the motor and slowly start to fry.
Hence the reason for turning over any pumps you might have that are impeller side up.
Tim
Old 01-15-2014, 03:09 PM
bturner2's Avatar
bturner2 bturner2 is offline
Make sure the valve is open.
Old 01-15-2014, 03:14 PM
tr6coug's Avatar
tr6coug tr6coug is offline
Boat: Mastercraft 2007 X2 MCX
I had something similar happen once. The motor would run, but no pumping. It turned out that the impeller hub was spun, so the motor would run, but the impeller didn't spin. The plastic hub should have a flat spot to mate with the motor shaft.
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
Old 01-15-2014, 03:16 PM
Boat: No Boat
I've seen this too.
If the pump overheats it will melt the impeller hub and wont turn.
Tim
Old 01-15-2014, 03:20 PM
ttu's Avatar
ttu ttu is offline
ditto! this happened to me last summer while on vacation at table rock. turns out i forgot to turn off the pump after you ^^^ reprogamed my timers! (best money i have spent)
knock on wood i had a spare!
