  #111
Old 02-03-2014, 09:48 PM
BrooksfamX2's Avatar
Boat: 2007 X2
Originally Posted by tr6coug View Post
running up your post count I see..........
MISS "B" HAVEN
OJ 522 14.75 x 15.5
http://www.crowniehq.net
Old 02-04-2014, 08:27 AM
amcmac's Avatar
amcmac amcmac is offline
Boat: X2
Is the device strong enough to pull the boat out of the water without the winch? I lube on a lake but have to load and unload my trailer every time I go out because I don't have a dock. My house is a quarter is a mile away. Can I load my boat using the ramp n clamp and trailer to my house without hooking up the winch?
Old 02-04-2014, 09:28 AM
JMLVMI's Avatar
JMLVMI JMLVMI is offline
Boat: 2007 X2 MCX
Originally Posted by amcmac View Post
I lube on a lake but ...
You do WHAT on a lake?
Old 02-04-2014, 09:33 AM
Traxx822's Avatar
Traxx822 Traxx822 is offline
HAHAHA
1 Corinthians Chapter 13 - 11
Old 02-04-2014, 09:40 AM
amcmac's Avatar
Boat: X2
[email protected] you swype and predictive text.
Sent from my SPH-L710 using Tapatalk
Old 02-04-2014, 10:14 AM
Towboatcapt Towboatcapt is offline
Boat: 1990 190 351W (sold) 1993 S&S 190 LT1 (sold) 1999 205 MXC (sold)
Looks great! I'm in!
“If you can't be a good example, then you'll just have to serve as a horrible warning.”
Old 02-04-2014, 10:23 AM
MasterCraft 4 Ever MasterCraft 4 Ever is offline
Boat: 1988 MasterCraft Tristar 190
Order #26...Now the work begins since I have to fabricate and weld a winch post. Want to eliminate the bar setup for my Tristar 190. Found PDF for boat buddy retrofit winch post dimensions on Team Talk.
Old 02-04-2014, 11:37 AM
tmacx2's Avatar
tmacx2 tmacx2 is offline
Order placed. On a related note, I have a boat buddy for sale. jk
Old 02-04-2014, 11:51 AM
Ramp-N-Clamp's Avatar
Ramp-N-Clamp Ramp-N-Clamp is offline
Boat: 2008 X2
Yes, the Ramp-N-Clamp is definitely strong enough to pull any boat up to 6500 lbs up a ramp without the winch strap. That is exactly what it was designed and tested for.
The reason the winch strap is needed for towing is to eliminate wear to the bow eye from the boat "bucking" up and down on the trailer. If your boat is fitted correctly to the trailer and it tows very stable you will be fine for the quarter mile.
Thanks,
RNC
Old 02-04-2014, 01:15 PM
tr6coug's Avatar
tr6coug tr6coug is offline
Boat: Mastercraft 2007 X2 MCX
OK, so do you need to cinch the boat down with the strap and then unlatch the RNC to prevent wear on the bow eye?
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
