Old 04-16-2018, 06:37 AM
brendosextreme brendosextreme is offline
Boat: 1997 Prostar 190
UFP DB42 caliper parts
Does anyone know if some parts for the UFP DB42 calipers are interchangeable with other calipers? (either from trailers or cars?)
The trailer I have is a Mastercraft 2000 C8 model. The parts are tricky to come by down here and the age of the trailer doesn't help.
Specifically I am looking for:
- The slider pin,bolt and bush/boot that the caliper is mounted on.
- Bleed screws.
I've noticed in some UFP documentation that the brake pads can be used from some cars (eg: 91 Dodge Spirit). Are the parts I am after used on the vehicles with compatible pads also?
Can the bleed screws from the DB-35 also be used on the DB-42 caliper?
Appreciate your help
Old 04-16-2018, 07:48 AM
Aquaholic Aquaholic is offline
Boat: Mastercraft X2 2003 5.7 TBI
I fully rebuilt my UFP brakes on my 03 X2 dual axle trailer from down here in Aus. Try http://www.karavantrailers.com.au/catalogue.php?cid=59
They should have all you need.
Cheers
Old 04-16-2018, 06:37 PM
Thanks Aquaholic. I've used KaravanTrailers before but the parts I need are not listed. I've emailed them to see if they can source the bits I need, but no reply as yet.
I'm actually finding the parts I listed difficult to find anywhere online, particularly the slider pin assembly. I am sure the bleeder screw is reasonably generic, and hopefully someone here will be able to clarify this easily. The caliper boot/pin is more elusive. It might be part of a rebuild kit which is why I missed it, but I'm just not sure.
Thanks again for your reply.
Old 04-16-2018, 06:49 PM
Table Rocker's Avatar
I have not seen the boot for sale by itself.
'96 ProStar 205 SD LT-1
brake, caliper, db42, ufp
