Old 01-11-2014, 03:38 PM
Ramp-N-Clamp's Avatar
Ramp-N-Clamp Ramp-N-Clamp is offline
Boat: 2008 X2
Ramp-N-Clamp automatic boat latch approved by MasterCraft
http://www.ramp-n-clamp.com/
Coupon code: teamtalk20
Hello Team Talk members,
We have been working with MasterCraft for the last 18 months while developing this product. I am proud to say that the Ramp-N-Clamp latch is now approved for all current MasterCraft models except the X55.
It will be available as an option directly from MasterCraft soon. It will also be available at your local MasterCraft dealer and was demonstrated to the dealers in Orlando last month during the MasterCraft Dealer Days.
Ramp-N-Clamp can also replace any current latch or roller for any year MasterCraft trailer.
I will attach some info and video links and work to answer any questions.
http://www.youtube.com/channel/UCG9KtHRxtftN-ZFgY35hOxg
http://www.youtube.com/watch?v=a1xMveTij-4
Highlights
No more bent pins from slight off center hits
No more marring the hull as long as hull is waxed
No more struggling to pull the pin with the bow eye
wedged against it
No more non serviceable construction if there is a
slight problem
No more uncertainty of operation
No more replacing every year
No more great concept with poor execution
Maximum boat weight 6500 lbs.
Winch strap must be used and tight while towing
Tips
Keep boat and Ramp-N-Clamp cover waxed
Make sure boat is fitted to the trailer, no rocking while towing or add a bow tie down strap
Find the depth your trailer and boat load best
NO MORE WET FEET OR SLIPPERY RAMPS
Easy Load, Easy Launch
To Load: Drive boat on trailer latches automatically
To Launch: Back trailer in water pull handle up to release boat
Easy installation
Simply replace your trailer's bow roller with the Ramp-N-Clamp
Works with boats up to 6500lbs.
Boat must be equipped with an extended Bow Eye
Works with V-hulls, trihulls and pickle fork boats.
Fits all trailers with 3 or 4 inch winch stand uprights*
*(Does not work with Shoreland’r trailers)
Stainless steel construction with Stoltz Urethane Cover to prevent damage to your boat
Works on boats with 1/2" EXTENDED bow eye.
Made in USA Patent Pending
Update
The Boatmate version is now available on www.rampnclamp.com
Thanks,
RNC
Old 01-11-2014, 03:46 PM
tr6coug's Avatar
tr6coug tr6coug is offline
Boat: Mastercraft 2007 X2 MCX
Looks nice. How much will it sell for?
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
Old 01-11-2014, 04:00 PM
Boat: 2008 X2
Even though we have been working together closely I do not have MasterCraft's pricing information. The price should be on the option list to dealers soon.
Old 01-11-2014, 04:28 PM
Mastercraftdave's Avatar
Boat: 2015 X23 SS 6.2L
Looks like a great product, curious as to how it holds up over time as the boat buddy was great but started to malfunction after repeated use.
I don't want to buy from a dealer as they will mark up the price 20%. I want to buy from manufacture.
I say that you get on good terms with all the teamtalk/MC loyalist and offer a group buy so those who aren't buying a new boat anytime soon could maybe help you push your product to non ski boaters....
Old 01-11-2014, 05:16 PM
MC25's Avatar
MC25 MC25 is offline
Boat: 2016 X30, 85 S&S
Question is, does it scuff the boat! That was my biggest peeve with the boat buddy.
-Aric
LONE STAR MASTERBASH 2018
Details released eventually
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
1985 S&S- For Sale
Old 01-11-2014, 05:37 PM
Boat: 2008 X2
It is our opinion that the previous latch was flawed by design.
We have Ramp-N-Clamp units that have been cycle tested for over two years and show almost no wear. The design of the moving part is centered so it does not move out of alignment with hits from the boat.
The Ramp-N-Clamp weighs 6 lbs and is made of stainless steel and Stoltz urethane. The previous latch was 1.5 lbs of stainless and plastic.
Stoltz urethane is the best bow stop material available in the world. Many other materials were tested and failed. This material definitely will not scuff the boat, and it won't leave any marks as long as the boat is waxed. It is the same material as the stock bow roller.
Old 01-11-2014, 05:45 PM
Stoltz urethane is the best bow stop material available in the world. Many other materials were tested and failed. This material definitely will not scuff the boat. And it won't leave any marks as long as the boat is waxed. It is the same material as the stock bow roller.
So I take it that was a hard No on the group buy?
Old 01-11-2014, 05:49 PM
Will it work to older boats? Sounds like only will be available via MC.
Old 01-11-2014, 05:52 PM
Boat: 2008 X2
Pictures of the Ramp-N-clamp automatic boat latch.
Old 01-11-2014, 05:58 PM
Boat: 2008 X2
Yes it will work for any trailer with 3-4 inch winch uprights and boat with the extended bow eye. MasterCraft has been using the extended bow eye since 1991.
It will be available online but this forum is not for advertising.
