Old 01-01-2014, 10:56 PM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
Pri G Gasoline Treatment
Has or does anyone use Pri G to treat their gas? A friend was telling me about it and how good the stuff supposedly is. I have my preference on gas treatment, but was just curious.
http://www.priproducts.com/consumer_products.cfm
Old 01-01-2014, 11:13 PM
PineLakeRumble's Avatar
PineLakeRumble PineLakeRumble is offline
Boat: 1994 Prostar 190
SeaFoam Fuel Treatment has worked well for us. Haven't seen Pri G on the shelves yet.
Old 01-01-2014, 11:16 PM
Some of the products out there are too much solvent - not enough oil... i.e. b-12 chemtool - be careful with b-12 way too much solvent..
main ingredient is mineral spirits for pri g
pri g msds
http://www.berkeywater.com/Other_Pro...ces/MSDS-G.pdf
Shellsol d60 msds
http://s05.static-shell.com/content/...60americas.pdf
Old 01-02-2014, 12:03 PM
CC2MC's Avatar
Boat: 2005 x-10
pri g msds
Shellsol d60 msds
Well, that being said, it would probably be pretty good for an engine that has not run in a while, ie a few years, just to get things going again. But if you have a great running engine, then go with something that provides more oil. That helps to explain some of the comments I have read about it.
Old 01-02-2014, 12:39 PM
I would do some more reading on the heavy solvent based cleaners. Some of the other boards heeded caution on those.
You may want to inspect the inside the rocker cover to see if there's any sludge build up. I am not a big fan of mineral spirit on seals, o rings... etc...
