Old 12-16-2013, 02:44 PM
M3lelena's Avatar
M3lelena M3lelena is offline
Boat: Xstar 13
help problem with XSTAR 2013 P ballast & display ?
hi all,
got a little problem with one of the ballast or the display on my Xstar 2013
when i hit the "fill all" button the "P ballast display" shows in less than 2 sec a 100% filled while the 2 other ballast are still filling at a quite normal speed. then the wake on the "Left" (if you are riding benhid the boat) is not well formed. foamy no matter what speed.
tried to use the "over fill" button for that ballast but doesn't seem to fix it. Not sure if the two are related..
Old 12-16-2013, 03:08 PM
MattsCraft's Avatar
Sounds like the Port tank timer is off, what time is it set to. Should be the same time to fill as the Starboard. Or, if this is not the case, try to shut off the battery switch for a few moments turn back on to reset the system.
Old 12-16-2013, 03:13 PM
M3lelena's Avatar
Boat: Xstar 13
Hi Mattscraft
where can i check what time it is set to?
Old 12-16-2013, 04:19 PM
MattsCraft's Avatar
In your ballast settings screen.
Send me a PM with your email and I can send you the Murphy manual.
Old 12-16-2013, 05:08 PM
M3lelena's Avatar
Boat: Xstar 13
you got PM
Old 12-17-2013, 01:36 AM
Stefan's Avatar
Stefan Stefan is offline
you can also find them here
http://www.mastercraft.com/manuals
you should be needing the first link
If You Find Too Many Capitals You Can Keep Them...I'm German
Old 12-23-2013, 03:07 AM
M3lelena's Avatar
Boat: Xstar 13
fill time on the P ballast appeared to be low..anybody knows the correct value for each ballast?
