Old 09-04-2014, 10:55 AM
SpokaneSteve SpokaneSteve is offline
Boat: 2007 X1
Rats - Gelcoat scratch - advice needed
Hello all:
I lost concentration for a minute coming into a dock and smashed it pretty hard resulting in a good scratch.
Name:  Scratch overall.jpg
Name:  scratch closeup.jpg
I emailed MC, gave them my HIN and got the details on my gelcoat colors. I ordered what I think is the correct color Spectrum kit from iboat.
Here are my questions:
1. Do I need to grind this scratch out to a more "v-like" shape? I have read that some people so that.
2. For sanding, the shape is slightly concave, should I sand my own wood block to match, use a foam block?
3. Does anyone know what the diamond shaped vent is for and whether there is some way to order a replacement? I never really even noticed it before.
Thanks much, Steve.
Old 09-04-2014, 11:05 AM
TXMC-06X2's Avatar
TXMC-06X2 TXMC-06X2 is offline
Boat: 2013 X25
I believe the vent is for your horn.
Old 09-04-2014, 12:41 PM
Jayhawk's Avatar
Jayhawk Jayhawk is offline
Boat: 2001 X-Star
Horn grill: http://mcpartsdepot.com/products/hor...-s-03-14-11088
Old 09-04-2014, 01:01 PM
cruiser cruiser is offline
I would grind it even. It looks like you have a rough and a sharp edge. Foam block and stay in the center of the scratch. The block will follow the contour of the side.
1981 stars and stripes -powerslot
sand with red metalflake stripe
Old 09-04-2014, 01:41 PM
Boat: 2007 X1
Thanks for identifying the grill. New one is ordered and on the way.
Are you suggesting that I grind more of a "U" shape or a "V" shape? I can get either type of bit for my dremel.
Thanks, Steve.
Old 09-04-2014, 09:40 PM
jgraham37128
Guest
Posts: n/a
I think the scratch is deep enough. I wouldn't grind it.
Old 09-04-2014, 10:53 PM
blackhawk's Avatar
Boat: 2006 X15 350 MCX
I wouldn't grind it. Just take some 100 or 150 grit sandpaper folded and sand down into the scratch. This will remove any loose pieces and also rough up any smooth spots for a good bond.
Apply 2 layers of painter's tape to both sides of the scratch. Apply the tape about 1/16" to either side of the scratch. Apply your gelcoat with a flexible plastic blade. Get some of the bondo applicators from the local auto parts store. The gelcoat will shrink after it dries, hence the need for two layers of tape. This will give you allowance for shrinkage and also extra material to sand down to get the repair flush.
As soon as you get the gelcoat smoothed out, go ahead and remove the tape. Don't let the gelcoat dry before removing the tape.
We defy the mafia!
Old 09-05-2014, 05:23 PM
FoggyNogginz's Avatar
FoggyNogginz FoggyNogginz is offline
Boat: 2017 X10
Location: Center Hill Lake, Old Hickory, and Norris Lakes in TN
I had one like this a while back, in nearly the same spot. I'd skip the grinding, and just sand. The gelcoat should match pretty nicely. Mine was nearly invisible unless I pointed it out under the right light. Good luck!
Sent from my RM-893_nam_att_206 using Tapatalk
"KC"
2017 X10 / 2012 X14v / 2002 X9 / 1998 PS205
Center Hill, Norris, & Old Hickory lakes in TN
Old 09-06-2014, 05:28 PM
ac505 ac505 is offline
Boat: ...
Without a doubt, grind it.
I used a carbide dremel bit doing some similar work on my boat. Search my posts and you should find it. The dremel opened it up to a nice U shape, made repair very easy.
Good luck, take your time, keep everything clean with acetone and spend some time wet flatting before polishing.
Old 09-06-2014, 05:55 PM
Easy fix like ac505 states... No worries.. Just take ur time
