Old 12-09-2013, 07:40 PM
imyourmaster's Avatar
imyourmaster imyourmaster is offline
Boat: 2008 X-2
Ballast Pump Timers
Can anyone shed light on the timer fuction of the ballast pumps? I have a '08 x-2... my ballast pumps do not seem to turn off when filling the tanks. They keep pumping after the tanks have filled and I can see water spewing out from the thru hull fittings. Same happens on emptying the tanks. I can hear the pumps running even after the tanks have emptied. Is this normal? I'm concerned that I might burn out the pumps and destroy the impellers especially on the empty cycle.
Old 12-09-2013, 08:11 PM
snork snork is offline
Boat: 07 xstar
you must have one of the reprogramed timer
thanks for the reminder I need to send mine off for the reprogram'n
Old 12-09-2013, 10:39 PM
Dalilamba Dalilamba is offline
Boat: 2012 X25
Deon, try disconnecting the battery for a couple minutes and that might reset your timers. It worked on my 07 X2 when I had it.
Old 12-10-2013, 09:05 AM
Boat: 2008 X-2
Will give it a try for sure. I disconnected the batteries last weekend so I should be able to test the next time I take it out.
Old 12-10-2013, 11:09 AM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
This post covers how to change the run time on them. I think the 2007 timers maxed out at 5 or 6 minutes and 2008 and up the timers max out at 20min.
http://www.mastercraft.com/teamtalk/...64&postcount=8
My boat doesn't have timers. I just run them until I hear the sound change. If you have the green impellers, they can be run dry for a while before it does any damage.
Old 12-10-2013, 05:46 PM
Boat: 2012 X25
Yes the 07 timers maxed out at 6 minutes
