Old 12-06-2013, 05:20 PM
Juiced190's Avatar
Juiced190 Juiced190 is offline
Boat: 04 X7
Quick Winterizing Advice Needed ASAP!
I live in middle tennessee and although we've had several nights below freezing I have yet to winterize my 96 190. All is good because it's in a heated garage. There's an ice storm coming through in about an hour and I have concerns about power loss if lines are down. Here's my question, should I drain the water from the block and manifolds and poor straight antifreeze down the raw water hose till its full. I'm afraid if I go with what I normally use, 50/50 marine, there will still be some water in the block and will dilute the 50/50 mix, rendering it much less effective. Any concerns with using straight antifreeze? I'm planning on going with the Sierra propylene glycol. Thanks in advance.
Old 12-06-2013, 05:23 PM
Boat: No Boat
If you don't start the motor and warm it up the AF won't get into the block.
You could pull the thermostat but you are still going to need to start the motor to push the AF into the block.
If all you can do is drain that is better then nothing. At least the water that is in the block will be able to expand a bit.
Old 12-06-2013, 05:39 PM
Drain the block - should be ok. My 95 was winterized by dry blocked method for 15 years in Iowa before I got it... should be ok.
Or do what CantRepeat says... pop thermostat house and pour water antifreeze that way.
Plus it take many hours of freezing 16-24 to freeze a block to crack.
Old 12-06-2013, 05:40 PM
1redTA's Avatar
1redTA 1redTA is offline
I'd drain the water from everything, pull the thermostat and fill with RV antifreeze, also fill the lines running to the manifolds, then open the petcocks and make sure the antifreeze comes out
1981 MasterCraft
19' Skier 351W PowerSlot
Old 12-06-2013, 05:46 PM
atthelake's Avatar
atthelake atthelake is offline
Boat: 2014, X30, 6.0 Gen2
Crank the heat in the garage, steal all the wife's coats and pack them in the engine compartment (while discussing with her the definition of sacrifice).
Seriously though, insulating around your engine/block with old rags, blankets etc. may help you out for a short period of time as well. Hope you make it through the storm okay.
Old 12-06-2013, 05:47 PM
jschildm jschildm is offline
Boat: 1998 ProStar 205
Drain the water and call it good. Just make sure the flow from the drains is good to ensure that no water is trapped in the block/manifolds.
Old 12-06-2013, 05:52 PM
jakethebt's Avatar
Boat: '96 Prostar 205 LT-1
I would drain the block and manifolds, heater and shower if you have them. That should be ok, but if you want to use anti freeze, use the RV stuff. The green stuff is really nasty and you can never get it all the way out. If you get caught with a green slick on your water, you could be in for huge fines and EPA clean up. They really freak anymore.
1996 Prostar 205 LT-1
Jerseydave's Avatar
TT Hero
As stated before, drain block (both sides) drain both manifolds.
Remove hoses from seawater pump, remove impeller. Remove both hoses from your trans cooler (the large water hoses!)
If you're still concerned, reinstall everything and remove t-stat and fill with RV antifreeze
Unless it's an LT-1, then use marine antifreeze that's safe for aluminum engines.
I was njskier on here.
Old 12-06-2013, 05:59 PM
MC25's Avatar
MC25 MC25 is offline
Boat: 2016 X30, 85 S&S
Personally I dont think a few nights and days with the power off will make it drop below freezing!
-Aric
LONE STAR MASTERBASH 2018
Details released eventually
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
1985 S&S- For Sale
Old 12-06-2013, 06:05 PM
Covi's Avatar
Covi Covi is online now
Boat: 2008, PS 197, LY6
Send a message via AIM to Covi Send a message via Skype™ to Covi
I agree. You'll be fine. You'll see the power is not even going to go out (that's not a promise).
86' 19 Skier, 351 PCM (sold)
2008 197 ProStar, LY6
