Old 11-30-2013, 07:47 AM
bturner2's Avatar
bturner2 bturner2 is offline
Looks like the stock set up got a lot better from when I got my boat granted the OP might have been responsible for a good deal of my original mess. Before and after pictures of my set up.
Big reason I went AGM and Blue Tops was the mounting plates available and their spill proof design. The cheap plastic boxes located in an area where they would be clearly visible, would take up additional room and would make installing/removing them difficult made the choice easy for me. This set up has worked well for me for 5 seasons.
Old 11-30-2013, 08:15 AM
ttu's Avatar
ttu ttu is offline
I have a 07 x2 and have been on my second battery since 2009 and it's a interstate. I only have one battery with 4 tower speakers, boat speakers and factory jl audio amp. I do use a battery tender between taking the boat out.
Old 11-30-2013, 08:33 AM
MLA MLA is offline
Boat: pontoon
Originally Posted by Trent 197 View Post
Guys,
I've got a 2011 X2. Bought it new and have not replaced the batteries yet. It's time. What do you guys recommend. Links to websites so I can see would be awesome.
Thanks!
Trent
It all depends on how you use the batteries and how your dual battery bank is setup. For just a typical marine cranking, you cant beat a quality lead-acid group-24. if your other bank is used primarily as a house bank, then consider a battery with a higher Ah rating like a dedicated deep-cycle lead-acid or AGM. Its important to compare the Ah to $$. There are some quality AGM batteries, but they are pricey for their Ah's.
If you rotate the use of your batteries equally and do not spend a lot of time playing tunes with the engine off, then consider a pair of dual purpose marine batteries.
Old 12-01-2013, 09:27 AM
bsloop bsloop is offline
Boat: 91' MC 240sc
Two years should not be "time" to replace batteries if properly maintained.
Plug in a battery charger/maintainer and you will ask this questions half as often......
Marinco or if you don't put huge charging demands on your bank, some of the Ctek like 7002 are very effective.
Old 12-01-2013, 10:04 AM
fskof's Avatar
fskof fskof is offline
Boat: 2003 Prostar 209 MCX
The factory battery from my 2003 prostar 209 lasted 9 years. I replaced it with a Interstate
Old 12-01-2013, 10:20 AM
scott023's Avatar
scott023 scott023 is offline
Boat: 2008 X45 Switch L18
Interstate. The Optima is overpriced and we have had two sets in our 45 before replacing (warranty) with the Interstates.
Old 12-01-2013, 02:24 PM
bturner2's Avatar
If you're going through that many Optima's something is wrong with the way they are being charged/maintained. I've personally "revived" 2 supposedly dead Optima's with my charger.
Go to YouTube and look up Optima charging. They have videos of them bringing back batteries that are supposed to be dead.
Old 12-01-2013, 03:50 PM
scott023's Avatar
These were brand new batteries that came in the boat. There were battery issues... Replaced when boat had 50 and 70 hours. No maintenance issues should occur with that little usage.
Old 12-01-2013, 03:52 PM
5 year old Exide never let me down... but I don't load it with a rockin' sound system - it will be replaced this spring when Menard's has it's sale... $43 for a group 24 marine starter...
Old 12-02-2013, 01:33 AM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
I've been down that road with Optimas and can say out of 5 batteries I got one that was worth a chit!
I've had them on maintainers and still died in 2 years. But one that ended up in my neglected old jeep keeps going. I don't get it.
To the op, find something other than optima IMO. I have had great luck with Odyssey batteries in my boat. Have 2 of the same batteries from 08 and '11. Put both in my truck a year ago before moving to AK and they just started a frozen diesel after sitting out at -20 this weekend.
Not bad!
'06 X2 MCX
