Old 07-01-2015, 02:41 PM
tockit's Avatar
tockit tockit is offline
Boat: 1989 190 Tristar
Camshaft Question?
I've attached a picture of a camshaft drive gear out of the short block I'm replacing in my boat.
The orientation is so that the top of the picture is the front of the engine, and you're looking down the distributor hole.
The oil pump drive shaft hole is on the left.
Can anyone tell me if this camshaft is LH or RH rotation?
I bought a new short block and the supplier tells me it has a LH rotation camshaft but it's cut opposite of my this engine (in this picture), and it doesn't mesh with my distributor drive gear.
This has me really scratching my head...
Thanks
Old 07-01-2015, 04:08 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
/spôrk/
Old 07-01-2015, 04:14 PM
Spork's Avatar
Boat: Sporkcraft
/spôrk/
Old 07-01-2015, 05:02 PM
tockit's Avatar
Originally Posted by [email protected] View Post
here is a top view through distributor hole front of motor is down in this pic, standard rotation (LH) cam gear is left of oil pump drive and you can see the teeth are right to left.
If the bottom of your picture is the front of the engine, then the cam drive gear is cut the same as the one in my picture. My picture is rotated 180 degrees from yours. Is that the way you see it?
Old 07-01-2015, 05:07 PM
tockit's Avatar
Standard rotation (LH) cam gear is left of oil pump drive and you can see the teeth are right to left.
You're kind of confusing me with this statement. Is my camshaft standard rotation or reverse rotation (LH)?
Spork's Avatar
Boat: Sporkcraft
/spôrk/
Old 07-01-2015, 05:12 PM
tockit's Avatar
yes...both your pic and my pic are of a standard rotation (LH) camshaft.
(LH) isn't reverse rotation?
Old 07-01-2015, 05:34 PM
Spork's Avatar
Boat: Sporkcraft
/spôrk/
Old 07-07-2015, 08:31 AM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
LH vs RH conventions may be different in the auto and marine world as they relate to standard vs reverse rotation. That is likely the source of confusion. In the marine world, RH = reverse rotation. Rotation is referenced from the rear.
