Old 11-17-2013, 09:10 PM
jradasaurus's Avatar
jradasaurus jradasaurus is offline
Boat: 2009 Mastercraft X-Star
Few random questions...
  • What appears to be the "silencer," sitting between the exhaust manifold and the muffler sprunk a leak. This is the 2nd time this has broken. The dealer said its a common problem and always has a few in stock. Is anyone familiar with this problem? Any solutions? I've heard someone applies more fiberglass to make it stronger. Also does anyone have recommendations to remove this thing from the hose? I can't believe how tight the hose is...
  • The chrome covers to my nav lights fell off, on both sides. The covers appear to be glued on which I think is incredibly cheap (I guess these aren't build by MC.) Has anyone faced this issue? Should I just glue it back on?
  • Is this garden hose connection for running the boat on land/out of the water- or is it only used for flushing the system? Do all boats has this?
  • Eyecandy. Cleaned her up and ready for winter storage.
Old 11-17-2013, 09:30 PM
lashburn1's Avatar
lashburn1 lashburn1 is offline
Boat: 2015 X20 SS
Garden hose is for flushing engine....typically after salt water us.
You can get this OPTION with out SaltWater series Boats.
For the most part you don't see them much, but they are handy
Old 11-17-2013, 09:32 PM
lashburn1's Avatar
Boat: 2015 X20 SS
Looking at your trailer , it appears you have a SS (SaltWater Series) boat?
Old 11-17-2013, 09:34 PM
scott023's Avatar
scott023 scott023 is offline
Boat: 2008 X45 Switch L18
The nav light covers can be glued back on.
Old 11-17-2013, 09:35 PM
To remove the hose use a hose removal tool http://www.walmart.com/ip/29937516?w...175196&veh=sem
those connections are good for flush IMO -- to run on trailer I recommend a bucket or bin... water from hose enough to keep water flowing thru jack... The heat will cause hose to stick muffler - a little anti-seize will keep it from sticking....
A little fiber glass matting and resin will fix up the muffler..
Old 11-17-2013, 09:44 PM
Jerseydave's Avatar
TT Hero
I don't have those silencers on my X-star but you could try using a heat gun or hair dryer on the hose to make it softer and easy to remove. You could also use a hose remover tool to slip under the hose (it looks like a rounded pick tool)
I was njskier on here.
Old 11-17-2013, 10:00 PM
Thanks for the input everyone. I bought the boat (2009) used from a guy on lake Norman, NC (he bought the trailer aftermarket). He told me the boat wasn't SS...how can you determine definitively if it is? I found this post. The boat definitely doesn't have hydraulic steering nor is it marked SS anywhere I know about.
Originally Posted by [email protected] View Post
1) Closed cooling 100% including the exhaust manifolds
2) Hydraulic Steering
3) Sacrafial zincs and annodes
4) addtional stainless steel
5) Flush kit
6) It will be marked as an SS edition
7) Normally a galvinized trailer has been added
8) scuppered interior
[email protected]
I'll see if I can find someone to apply more fiberglass to stop the leak.
Old 11-17-2013, 10:07 PM
snork snork is offline
Boat: 07 xstar
for what I can tell :in the voice of Maury: IT IS NOT AN SS
Old 11-18-2013, 08:58 AM
JohnE's Avatar
JohnE JohnE is offline
Boat: XT22
The bow light cover on my 09 came unglued and disappeared as well.
Old 11-21-2013, 09:07 AM
WakePowell WakePowell is offline
Boat: Mastercraft X-Series
The navigation light cover came loose on my X-45. They are made by a thord party and are available from parts suppliers. I got a replacement from iBoats online.
exhaust, navigation light
