Old 11-12-2013, 06:03 PM
bcd bcd is offline
Boat: 2014 X-2
new boat stereo options
DHPRO's thread got me thinking about my options again. I'm getting 2014 and I pulled my system out of my 2012. Here's what I've got sitting in my basement: 12" RF P3 sub powered by RF Prime 1000W RMS amp, 2 WS rev 8's for the tower powered by a RF R600-4D, bridged to give me 300W RMS X 2, and an Alpine 500PDXF6, which gives me 150W RMS X 4 for the in boat speakers.
My original plan was to get the standard stereo and then install my same system. The sub amp is mounted on the sub box and sits under the coffin seat. I mounted the other 2 amps above the batteries.
Here are my concerns with the original plan:
My tower speakers were intermittently cutting out. The amp was saying it was going into protect mode from a short circuit. I checked my connections when I pulled everything out, so either there was a problem with the factory portion of the wiring, or my amp has an internal issue. Any ideas on how to verify my amp is good?
I won't have the upgraded Fusion 700 which gives you better audio control from the driver's seat, including zoned volume control. I guess I could always buy it aftermarket and install it myself for $420.
The other option is to get the high performance stereo option, which gets the upgraded Fusion 700, a sub and a 5 channel amp for the sub and in boat speakers. The in boat speakers would be underpowered, unless I install my amp, but then I don't have an amp for the factory sub. I would still install my sub and tower speakers and tower speaker amp. The other option is I could leave the in boat speakers powered by the factory amp and use my old in boat speaker amp to power the tower speakers since my original tower speaker amp is questionable. I don't want to increase my number of amps because there just isn't room to mount them, so that gives me the 1000W amp mounted on my sub box plus 2 amps over the batteries.
Any thoughts/recommendations?
Old 11-13-2013, 09:05 AM
ol1970 ol1970 is offline
Boat: 2014 X Star 7.4L
The Fusion 700i is one of the reasons that I can wait to get my new boat...that is an absolute must in my opinion. If I were you, I'd keep the amp and subwoofer...go all stock JL including 4 towers and then get a 750/1 for the towers or a 600/4. Get the remotes with the Fusion...it is awesome since you can scroll tracks on the iPod and adjust the volumes independently. You'll spend a bunch more money trying to do it yourself vs. what the factory can give you as a baseline from which to build upon.
Old 11-14-2013, 08:11 AM
bcd bcd is offline
Boat: 2014 X-2
I don't want to redo what I have. I'm reusing my sub and Rev 8 tower speakers. My debate is if I get the high power stereo option, I have a second sub to power and the amp I will get from the factory will only give me 75W to each in boat speaker. Either I keep the 5 ch amp and leave the boat speakers a little under powered, or I have to spend more money to get a higher power 5 ch amp. Or am I wrong on the factory amp rating? I don't want to end up with 3 separate amps to power the tower speakers, in boat speakers, and factory sub. I don't think there is room to mount all 3 easily.
Old 11-14-2013, 09:04 AM
My friend has a very similar set up to what you are talking about. Here is what I can suggest. Take the amp that comes with the boat out and put in the 900/5 like he did...huge upgrade, factory amp isn't enough IMO. Either trade-in the amp Mastercraft gives you or sell it on Ebay or something.
Tower speakers...use whatever amp is running your Rev 8's currently. For your sub, use your current amp as well. There is PLENTY of room to mount things. My current plan is I'll be pushing a little over 3000W through 4 amps...200W to each of the 10 JL7.7's 200W to the free air, and 1200W to my ported sub.
Old 11-14-2013, 11:21 AM
MC25's Avatar
MC25 MC25 is offline
Boat: 2016 X30, 85 S&S
Don't waste your money on the fusion stereo. I can't understand why mc went this direction, because all the fusion products I know of are absolute garbage. Just get a ws 420 eq. More control at your fingertips than the fusion would give you, and it probably won't break.
-Aric
LONE STAR MASTERBASH 2018
Details released eventually
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
1985 S&S- For Sale
Old 11-14-2013, 12:18 PM
What did you find the issue to be with the Fusion products? I was blown away at how well it worked on the '14 model compared to my crappy old Clarion head unit paired with the WS eq. (which I thought worked great too before seeing how the technology had evolved)
For me it is about being able to turn down or off the tower speakers from sitting on the back platform since a part of my lake has a noise ordinance, and also being able to access iPod and scroll through playlists while I'm standing behind the boat on the sandbar...not sure how you accomplish this using any other system ?
Old 03-07-2014, 10:13 AM
bcd bcd is offline
Boat: 2014 X-2
I ended up going with the high power option. My plan is to add my sealed 12" sub with 1000W RMS under the coffin seat, add my 2 rev 8's to the tower and power them with a 4 ch amp bridged to give 300W RMS to each. Right now, I'm planning on leaving the factory amp for the in boats and free air sub. I might change my mind when I get the boat, hear how it sounds, and see how much space I have available for amp mounting.
I saw on another post someone mentioning that adding a free air sub in the same space as an enclosed one can actually have a negative impact. Am I at risk of this even if the free air is on the other side of the boat? There aren't huge openings from each seat to the rear engine hatch, but they are still pretty big to allow air movement. Do I try it to see how it sounds with and without the factory sub being powered? If it is negatively impacting, will it not sound as crisp, or how do I tell?
Old 03-07-2014, 11:02 AM
David Analog's Avatar
Boat: N/A
Unless the two subwoofers are identical and side-by-side with the same orientation, you do not want two subwoofers. The results are unpredictable but generally two asymmetrical subs will have a different phase response, because a) they are different subs that are loaded differently, and b) they are in different locations with a different orientation/direction.
The impulse response will be poor because they cannot be time aligned, just smeared bass, and the bass performance will be hot and cold as you move around the cockpit. It's a problem especially with the longer wavelengths played by subwoofers.
Then you have one subwoofer with considerably more surface area that will clearly dominate.
Old 03-07-2014, 11:48 AM
bcd bcd is offline
Boat: 2014 X-2
Now that I've learned all of that, I should have gone without the high power option and installed the upgraded fusion myself. It's all I was really after. My original thinking was I didn't want to have to cut out the fiberglass (the 2 options are different sizes), so if I paid a little more, in addition to getting the head unit already installed, I also get a 2nd sub (although with a lot less power than my current) to supplement.
I guess I'll install my components and see how it sounds. I can always turn the gain down on the factory sub.
Old 03-07-2014, 12:22 PM
Boat: N/A
Many place a larger subwoofer and enclosure directly behind the opening once occupied by the factory IB sub. Then they add a grill to function as a vent. If your enclosure will fit there, then you are ahead by having the fiberglass opening already cut in.
