Old 11-18-2013, 02:23 PM
JayBrown JayBrown is offline
Boat: 1976 master craft stars and stripes
How to test a speedometer
I have my boat all winterized and have a new plate for my speedo. How would I check to see if it works?
Old 11-18-2013, 04:40 PM
drschemel's Avatar
Boat: 1990 Tristar 190 Sport
Are you just want to see if the needle moves? You can blow in the hose with your mouth. They work on air pressure. (actually the difference between the static water pressure and the moving water pressure in the pitot tube with air in the tubing transmitting the pressure to the gauge). Otherwise, the hose just needs to be clear between the pitot and the speedo.
Old 11-18-2013, 05:03 PM
Yes I just want to see if the needle will move
Old 11-18-2013, 05:39 PM
Just blow lightly. It doesn't take much to get it moving. Any compressed air will be too much. Even from a spray can of air.
Old 11-18-2013, 07:02 PM
Okay thanks guys if it dosn't move where should I go from there?
Old 11-18-2013, 08:25 PM
Check the hose from the pitot... and move your way to the speedo.
Old 11-19-2013, 09:55 AM
drschemel's Avatar
I think if one of my speedo's crapped out and no longer worked, I would get the GPS replacement module and forget about the pitot tube.
If you put a hose directly to the back of your gauge and it didn't work, then there must be something inside the gauge that is blocked or corroded.
http://www.classicboatwork.com/class...e/agr/agr.html
