Old 11-11-2013, 07:07 PM
jgraham37128
What size impeller puller?
Jabsco sells two different size impeller pullers. One is up to 2.5 and the other is 2.5 to 5". I have a 2010 X2 what size of puller do i need?
I assume it's the large one but want confirmation.
Old 11-11-2013, 07:10 PM
You can use 2 paint can openers...
http://www.mscdirect.com/product/829...&026=-99&025=c
I have this one... http://www.skidim.com/prodinfo.asp?number=6503606 but rarely use it.. impellers comes out annually so it never sticks.
Old 11-11-2013, 07:20 PM
jgraham37128
I tried the two paint can openers. Got it about 1/8th out. Bumped the starter and etc... No luck.
Old 11-11-2013, 07:24 PM
ttu's Avatar
ttu ttu is offline
I used to use a puller when I had my 05 supra ssv 22. not very much clearance on the x2. I have found that removing the cover and spraying just a little wd40 then bumping the starter the impeller pops right out. give this a shot before buying the puller.
Old 11-11-2013, 07:31 PM
jgraham37128
I used wd-40 too. Still no luck. Problem is impeller is at the stern so you are hanging over the motor trying to push the impeller to the rear of the boat. Hard to get any leverage. I thought based off all the post it would come out but I gave it a very good effort. I did the two paint openers with no luck. I have a very small pair of channel locks and was able to get it out a little. Then I sprayed with wd-40 and bumped the starter. Tried again to pull out and no luck. Bumped the sarter again, and still no luck. Probably spent 30-45 minutes total to get it out.
Old 11-11-2013, 07:46 PM
ttu's Avatar
ttu ttu is offline
hmm, that is interesting. we have the same boat and I used the impeller puller the first time and after some bloody knuckles I finally got it out. I have been using the wd40 for 5 years and have had no issues.
in re: to size I don't remember. I sold mine to a supra guy.
Old 11-11-2013, 08:16 PM
jgraham37128
Yea, I changed it out last year but had an impeller pulley from a friend that works on boats.
Old 11-12-2013, 10:26 AM
16 years owning my MC and I had no idea an impeller puller tool existed...
If it's that stuck, have a replacement on hand, you're going to destroy it on the way out... get two screw drivers and go to town on it. give it hell.
Old 11-12-2013, 10:28 AM
tkemperdc's Avatar
tkemperdc tkemperdc is offline
Boat: BOATLESS :2013 X Star, cute pumpkin motor, 2008 XStar LY6 (gone), 2006 X-15 (gone)
I too had no idea such a tool existed, the x-star is not as bad as my x-15 was due to motor placement.
Old 11-12-2013, 10:30 AM
ttu's Avatar
ttu ttu is offline
this is the one that skidim sells. i don't see where they offer a different size. this is the same exact one that i owned.
