  #31
Old 11-11-2013, 12:48 PM
Awesome now I just got to find the cross reference. This is why love this forum
Old 11-11-2013, 01:03 PM
Waterskibum Waterskibum is offline
Boat: 93 S&S 190
Originally Posted by gsxrjtt View Post
SSSSSSSSUUCCCCEEESSSSSSSSSS!!!!!!! MIKE205 Thanks a ton.. Talked to indmar and they Have just gotten 7 of these sensors from a closed wear house as I hear. They still do not make these and do not know who or when they will be reproduced. I just ordered four of them.. yes is know 2 for me and 2 for future boat or any TTer with the same needs as mine.
Sweet! Calling the shop now to get two for me. Mine are getting iffy and do not want to be down either.
Old 11-11-2013, 01:24 PM
gsxrjtt's Avatar
gsxrjtt gsxrjtt is offline
Boat: changes every month
call that num mike205 put up .. free shipping
Old 11-12-2013, 11:36 AM
Got a reply from Indmar - only 7 left - then no more from indmar... working on getting info from Delphi.
Old 11-12-2013, 11:56 AM
Table Rocker's Avatar
Thanks Mike!
'96 ProStar 205 SD LT-1
Old 11-13-2013, 01:13 AM
ok...delco remy part is obsolete 10456123 - so the chase is on for the interchange.
Old 11-13-2013, 04:38 PM
okay not good news - not getting any cross references on this part from any manufacturer. What I believe we need to do is get the spec's on this product (neither AC Delco or Remy) have this info. I am hoping Indmar will have the specs they wanted for this piece of engine management and then we can find another crank sensor that will do the same thing.
Specs look something like this...
Relative timing accuracy 1
High stability—360 repeatability 0.1
Operating temperature range -40C to 150C
Air gap with appropriate target wheel 0.1 mm to 2.5 mm
Environment Designed to withstand salt spray, humidity, thermal changes, automotive fluids, and general automotive environments
Operating voltage 4.5 V to 16 V
Output voltage (high state) V pull-up (3-wire), or 14 mA (2-wire)
Output voltage (low state) < 0.5 V (3-wire) or 7 mA (2-wire)
Current draw ≤ 16 mA
Rise time < 5 μ (Rpw = 500 Ω/C, out = 10 ρF)
Fall time < 2 μ
Output current limit < 50 mA
Output leakage current < 10 μA
Old 11-14-2013, 05:15 PM
gsxrjtt's Avatar
Xmas came early today
Old 11-14-2013, 05:45 PM
[how does it compare in size to the other ones you bought?
Old 11-14-2013, 07:24 PM
gsxrjtt's Avatar
exactly..... going in the morning to shove them in
