  #101
Old 02-07-2014, 03:25 PM
Originally Posted by gsxrjtt View Post
Yes still for sale.. I just didnt feel right letting it go with out firing right.
So After about 6 hours of checking, rechecking, hooking up the computer and diag. Everything was checking out ok with no codes. Finally traced with proab to ignition, From there we checked grounds and voltages, Then chuck Finally looked at the connector that goes to the ign module. found if we wiggled or held it we would get some fire and coughing from the motor. so we took of the connector and found some of the pins were off so tried as much as he could to realign them. Put the connector back on and used a pin through the back of the connector to apply ample pressure to the connections and BAM about two turn overs and it fired right up. Turned if off then on fired up. Let it run for 5-10 sec and throttled it up to blow out any build up in the engine. turned it off then back on again.
Rockman had a similar issue... Connector on that ignition module
Stopped in at Napa took a look at the PC7 Crank Position Sensor. It's measurements
were - 18mm(.71) in diameter - 2.16 deep - the nipple was .19 inches. I noticed that this sensor is used in very many applications.
They did not have the PC122 (standard motor products) or the AC Delco 213-336.
Old 02-10-2014, 09:26 AM
Waterskibum Waterskibum is offline
Boat: 93 S&S 190
Sorry all I got busy on projects this weekend, and could not get the CPS out of the boat and go to Autozone. Any updates this weekend Mike?
Old 02-10-2014, 11:09 AM
No updates.. have a call into Indmar this AM -
Old 02-15-2014, 03:35 PM
jim826 jim826 is offline
Boat: 01 PS 209
Charlie at Lake WI Ski boats thinks that he may have found them also. he is waiting for some specs to be sure. I'll keep us posted if I learn anything new. I haven't ordered anything yet from ACW.
Old 02-15-2014, 04:39 PM
awesome! I think $120 is not that bad for a boat part unless that part can be bought for less $35 at an auto parts store. Also, we need guys like Action, Midwest to be able to keep their lights on --
But it's also fun to find these parts. Too bad I don't have an LT1 in the garage and an oscilloscope - would have been a fun facet to this project.
Old 02-15-2014, 04:48 PM
John 3:16-18
Old 02-15-2014, 05:07 PM
supreme112279 supreme112279 is offline
Boat: 1996 mastecraft maristar 225
I've noticed this thread. Is this something I should be concerned with because I have an lt1. I tore down an lt1 a few years ago from a camaro and didn't notice a sensor. I"ll scope out my motor tonight and look for what you guys are talking about
Old 02-15-2014, 05:13 PM
Table Rocker's Avatar
Since Indmar used the NorthStar ignition, they have two crank position sensors that the Camaro didn't have. I would think it is uncommon for one to fail, but if you need one you want to be able to get one.
'96 ProStar 205 SD LT-1
Old 02-15-2014, 05:47 PM
only thing that I have found to make them fail is heat. Comaro used optispark I believe - but I most likely am wrong. The MC Crank Position Sensor is a VR type and develops and analog voltage signal. The critical points are diameter to fit in the hole, length - not too long and not too short, and then the mount.
here's how it sets up -- prolly not the completely correct diagram but prolly very close.
