Old 09-04-2017, 09:10 PM
Canwan Canwan is offline
Boat: 2008 MC X2 MCX
Noise when in gear at idle
My 08 X2 has a squeaking noise noise when in gear and idle RPM. Almost a nails down chalk board sound. As soon you get on the throttle it goes away. If you put it back in neutral the noise goes away as the prop stops turning. I always assumed this was normal but a friend riding with me this weekend seems to think it is not. It is almost a harmonic sound resonating through the hull if that makes sense. It's not terribly loud but you can definitely hear it clearly in the boat. Any ideas?
Old 09-05-2017, 01:24 AM
Flexx's Avatar
Flexx Flexx is offline
Boat: 2006 Mastercraft X2
Hey,
every Tranny i ever run in my MCīs was a bit noisy. Donīt worry too much..
Check Transmission Oil and Oil Level.
There was a Thread in wich was said, that another Oil in the Tranny (i believe 15W40 Engine Oil) could stop most noises in the Transmission.
Do you have the ZF Hurth?
Greets from Germany,
Felix
Old 09-05-2017, 08:15 AM
I am 99% sure it is the ZF but I will double check. This noise sounds like metal on rubber perhaps? Tough to explain and my video did not turn out.
Old 09-05-2017, 09:44 AM
Flexx's Avatar
Check that Thread, it might help you to figure out witch noise it its and if it is normal..
http://www.mastercraft.com/teamtalk/...e+transmission
Felix
