Old 11-01-2013, 12:16 PM
Bohmer410 Bohmer410 is offline
Boat: 2002 X30 3,000 Ballast
02 X-30 with 5.7 260hp, is that Enough to Surf?
Hello, I'm looking at buying a 2002 X-30 with the Indmar 5.7 260HP motor. I would really like to surf off this boat. So I was planning to replace the ballast system with 750 bags in the rear lockers and upgrade the pumps. In 2002, one of the optional motors was the 8.1L with 425hp. 425HP compared to 260HP, seems like it might be underpowered. My question is, will the 260HP motor be able to do what I need it to do? Or should I look for a different boat with a bigger motor? Thank you
Old 11-01-2013, 12:27 PM
scott023's Avatar
scott023 scott023 is offline
Boat: 2008 X45 Switch L18
It won't be under powered, it may just feel a bit sluggish out of the hole if you have a lot of extra ballast in the boat.
Old 11-01-2013, 12:33 PM
EarlyriserX9's Avatar
EarlyriserX9 EarlyriserX9 is offline
Boat: 2016 X30 6.0L
I could be wrong, but I think the 5.7L in 2002 was actually 310HP?
Old 11-01-2013, 12:47 PM
Tristarboarder's Avatar
Boat: 2002 Xstar
^ +1 310 hp. Will be enough, prolly just need a different prop to accommodate the extra weight....
Old 11-01-2013, 01:06 PM
Rossterman's Avatar
Boat: 2001 prostar 205V
Yep 310 hp base engine called the predator w/tbi. Optional engine was rated at 350hp but really~325hp. I have the base engine in my 205v with sacks and it has plenty of power. That being said, I always loved big block Chevys and the 425 hp version has all the good stuff so a tempting option for you to consider...
Old 11-01-2013, 01:08 PM
310HP sounds much better than 260HP. 310HP should do it. Thank you.
Old 11-01-2013, 01:28 PM
corey's Avatar
corey corey is offline
Boat: X10
In 2002 the base engine would have been a 310 hp 5.7 liter engine called a Predator, basically it is a throttle body injected chevy 350. The upgraded engine would have been a 330 hp 5.7 liter engine called the LTR. The LTR was a multipoint fuel injected engine. Photos below. Both will get the job done and as near as I can tell (from driving them) the low end grunt strength is identical.
Old 11-01-2013, 03:03 PM
swatguy's Avatar
swatguy swatguy is offline
Boat: Nautique
Agreed with the above. Should be 310hp and it's plenty when propped correctly. Consider 500 for a good prop into you budget as well.
CURRENT: 2008 SANTE 210
2000 Mastercraft Xstar
2003, Ski Centurion Cyclone
88 2001 Nautique
Old 11-01-2013, 08:50 PM
uplander uplander is offline
Boat: MC 2002 X30
you can surf, make sure to check prop for correct dia and pitch also. I put a 900 in the port locker and had a blast all summer.
wakemaker sells a kit that installs in about 10 minutes
2002, 5.7, power, surf, x-30
