Old 10-27-2013, 08:37 PM
John 3:16-18
Old 10-27-2013, 08:39 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
Originally Posted by strad View Post
Hmmm. Not disbelieving you necessarily, but I just checked, and my engine turns counter clockwise as viewed from the flywheel end. I believe that is standard rotation? The sellers are saying the E5JL-12100-CA is for a reverse rotation engine. . . I'm lost here.
E5JL-12100-CA is the tag on my 1989 LH rotation 351w so I can assure you that is the correct distributor for a LH, CCW or standard rotation Mastercraft Ford engine. I'm not going to speculate on the sellers description.
/spôrk/
Old 10-27-2013, 10:47 PM
strad's Avatar
strad strad is offline
They say a picture is worth a thousand words. . .
Yes indeed! But I broke one off on the other side now. It broke near the head so should be ok. I ordered a socket with an integral u joint to get number four out. Those are hard to find.
Old 11-14-2013, 10:44 PM
strad's Avatar
Ok got the exhaust system restoration done. As for the distributor, if I grab the rotor and turn it back and forth through the advance, I can feel a "bump" about halfway. I discovered that if I manually turn the rotor over that bump and get it to base timing, the engine will fire up immediately when I go to start it. So I am sure that the rotor is getting stuck, and that is the problem. I may get a nos distributor, but it would be interesting to fix this one if possible. Already tried some wd40, but that didn't help free it up at all.
Old 11-15-2013, 05:15 PM
John 3:16-18
Old 11-15-2013, 05:28 PM
strad's Avatar
Oh I thought you were suggesting it for the stuck broken off bolts! I guess it wouldn't hurt to put it in the distributor mechanism.
Old 11-15-2013, 05:30 PM
John 3:16-18
Old 11-15-2013, 06:56 PM
strad's Avatar
The bolts are all taken care of. 20 to the machinist and the two nasty ones were out. But I do need to have a working distributor!
