Old 10-25-2013, 11:23 PM
Allstricker Allstricker is offline
Boat: Mastercraft, sportstar 190, 1999, 5.7lt vortec max
5.7lt vortec max firing order
Does any one know the firing order of a 99 sportstar with a 5.7lt vortec max?
Chris
Old 10-25-2013, 11:34 PM
Table Rocker's Avatar
1-8-4-3-6-5-7-2
'96 ProStar 205 SD LT-1
Old 10-26-2013, 12:08 AM
Thank you, Any chance you can help me with where to start on the cap?
Chris
Old 10-26-2013, 01:02 AM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
Are all the plug wires off and if so has the motor been rotated?
Assuming that is the case, watch this video: http://www.youtube.com/watch?v=XMg0S21Sjkw
Old 10-26-2013, 10:13 AM
Chris
Once you're done finding 0BTDC, use a black permanent marker to mark the distributor base and the block where base timing is at 10BTDC and also mark the inside of the distributor, where the rotor is pointing. Then, mark the outside of the distributor where the cap rests- put a mark at the #1 and #8 wire positions, so you'll be able to see the direction of rotation. Mark the plug wire boots, too. Makes cap replacement much easier and when the wires are changed again, mark the new ones.
Old 10-26-2013, 12:39 PM
I just had two wires off and mixed up. With the firing order I was able to figure out where they went. Thanks all.
Chris
