  #31
Old 11-07-2013, 08:01 PM
TOO-TALL's Avatar
TOO-TALL TOO-TALL is offline
Boat: Mastercraft X2 2003 mcx
Originally Posted by Skyskiguy View Post
Dealer records indicate "Engine overheated and started to smoke" back in July of 2009.
They replaced a toasted impeller and dug/flushed out the pieces of rubber, cleared the codes, and it ran fine.
Check service records PRIOR to buying a used boat!
Dealer says hard to believe that an overheat could cause valve and/or ring damage because the boat would have gone into limp mode at 200 degrees.
Thoughts?
I feel your pain...When my motor blew I got no "limp" mode or over heat alarm.And I know it got hot.My problem was both head gaskets blew, water in the cyclinders...game over.
I've got a tread on here motor blew 1008 hrs.
Good luck...hope you find a easy fix.
---Animal house
Old 11-07-2013, 08:10 PM
TOO-TALL's Avatar
What are BG products?
---Animal house
Old 11-07-2013, 08:31 PM
Skyskiguy Skyskiguy is online now
Boat: 2006 X30
BG specializes in petro chemical additives for engines. Sold mainly through auto dealerships and service shops. http://www.bgprod.com/company.html
Old 11-07-2013, 08:45 PM
Boat: 2006 X30
Wow. Fortunately I'm not in that bad of a situation.
Old 11-07-2013, 08:53 PM
Boat: 2006 X30
Take a look at the oil after the BG treatments vs. new Rotella 15w40. Also, plugs 2 & 7 after treatments. These plugs were quite clean in the previous photos - all the plugs were pretty nasty after the BG did it's thing.
Old 11-08-2013, 06:48 AM
Bouyhead's Avatar
Bouyhead Bouyhead is offline
Boat: 2008 22' Progression
For how long did you "cruise" at 5000/5200 RPM's? My ZR6 is rated for 5400 RPM Max and 4000 RPM's continuous cruise. I know these motors were designed to spin but prolonged operation at WOT or close to it will eventually have some negative effects. With that said I can't define "prolonged" but my old TBI has seen WOT a few times but only for the occasional barefoot run which is only going to last 30-45 seconds at best.
Old 11-08-2013, 10:20 AM
Boat: 2006 X30
Ten minutes, maybe.
Old 11-08-2013, 10:35 AM
Boat: No Boat
Snake oil as you call it or additives rarely do anything good that is long lasting. It's kind of like a band aid that's gonna hurt when it gets removed.
Tim
Old 11-08-2013, 11:23 AM
Dylan's Avatar
Dylan Dylan is online now
Boat: 15' VALCO
I worked at a both an independent higher end auto shop and a Ford dealer while in college, and they both swore by those BG products. Interesting to see the treatment actually did bring up the compression a little. Out of curiousity, did you ever scope the cylinders?
Old 11-08-2013, 11:38 AM
Engine overheat causing engine to smoke? Never a good thing - obviously. I bet there is some underlying issues that will remain. Too_Tall's boat never smoked on that ugly day. But his thread does show some nastiness caused by over heat.
Not wanting to be the downer - but over heat causes sooo many problems that can show up later.
Good luck on the cheap repair hopefully - I personally would have the head gaskets replaced if I knew it had an over heat situation in the past along with smoke. Not much real estate between cylinders. Not cheap - but you get intake and heads reseated and new gaskets. IMHO... the engine guru's here know much more than me.
