Old 10-24-2013, 02:32 PM
prostar205er prostar205er is offline
Boat: ProStar 205, 1994, LT1
So that is the thermostat...the triangular shape box on top where all of the hoses converge? Good to know. So some of you out there open that up and pour your antifreeze in there?
I have a fake lake that I use to suck up the antifreeze. I don't always run the engine with water first to heat it up though (in part, so I don't scald my hands when I'm draining everything). When I'm sucking antifreeze into the engine I usually see my temp get up into the 200s. Is that sufficient enough to get the engine to open up to the antifreeze? Just curious as I've been doing this for years and have never had an issue.
Originally Posted by bochnak View Post
My motor is an Indmar, not sure what yours is? Your boat is probably carbed and does not have a knock sensor like mine.
Thermostat is on top and personally would not remove it. Drain all water and let the impeller suck the RV through the motor.
Old 10-24-2013, 02:37 PM
CruisinGA's Avatar
Boat: '01 X9 330HP
Where are you getting it for $2? Triangle shape with 2 holes?
No I pull the two large bolts, entire thermostat housing. Regular chevy vortec thermostat gasket
Skidim has it for $2.95.
http://www.skidim.com/prodinfo.asp?number=RM0121
Bailey
'02 X-9
Lake Blue Ridge
Old 10-24-2013, 02:45 PM
bochnak bochnak is offline
Boat: 94' Prostar 205 - Indmar 5.7 TBI
I did it with cold engine and RV distributed throughout. If you look at the t-stat setup, there is a 5/8" bypass hole.
-Matt
Old 10-24-2013, 02:50 PM
Where is that (t-stat setup)? I've been doing my own maintenance for years and have never opened the t-stat. Would I see this if I opened up the triangle where the four hoses converge?
Old 10-24-2013, 02:56 PM
http://www.skidim.com/prodinfo.asp?number=98-5006
On mine it is the smaller hole in this gasket.
-Matt
Old 10-24-2013, 02:57 PM
This is the one I need:
I thought I paid more for some reason.
-Matt
Old 10-24-2013, 02:58 PM
Thanks! Is there ever a reason to need to open that housing (other than for your winterization process of course)? Just curious if there is anything I've been neglecting...
Old 10-24-2013, 03:09 PM
CruisinGA's Avatar
Boat: '01 X9 330HP
You are splitting the tstat housing. If you remove the entire tstat housing you use the gasket I posted.
Bailey
'02 X-9
Lake Blue Ridge
Old 10-24-2013, 03:31 PM
blackhawk's Avatar
Boat: 2006 X15 350 MCX
I don't understand the need to remove the thermostat housing. If you just take off the large hose from the engine water pump, you can pour your antifreeze in that way. The AF will flow backwards through the water pump and then fill up the engine. On my MCX, after about 2.75 gallons, the AF starts coming out of the thermostat housing where I removed the large hose. You just have to hold the end of the large hose higher than the thermostat housing.
Old 10-24-2013, 03:40 PM
Oh, OK. I had to replace the t-stat & gasket. Didn't know there was another below that.
-Matt
