Old 10-26-2013, 10:40 PM
Bouyhead's Avatar
Bouyhead Bouyhead is offline
Boat: 2008 22' Progression
I pad makes me post one at a time
Old 10-26-2013, 10:41 PM
Bouyhead's Avatar
Old 10-26-2013, 10:53 PM
Bouyhead's Avatar
Originally Posted by D3skier View Post
instead of cutting off the harness can you use a small all and push the wires out to be able to connect the wires directly to the new harness that fits the new motor?
The gray ends will plug into the harness on the new motor, so I'm thinking ill just hard wire the boat end so I can still just unplug if I ever have to pull the motor.
Old 10-26-2013, 10:55 PM
Bouyhead's Avatar
One thing that worked out great today was crating up the ol' TBI to be shipped.
Old 10-26-2013, 11:36 PM
Ben Ben is offline
Boat: '94 PS205 LT1
Is that the boat carpet or do you have something sacrificial in place? I would hope so.
Old 10-27-2013, 08:32 AM
1redTA's Avatar
1redTA 1redTA is offline
Lookin good
1981 MasterCraft
19' Skier 351W PowerSlot
Old 10-27-2013, 11:14 AM
scott023's Avatar
scott023 scott023 is offline
Boat: 2008 X45 Switch L18
Originally Posted by Bouyhead View Post
Thanks, the main reason is for Zero Off speed control, and I got a pretty good deal on this motor as it was a leftover. BTW, that new avatar freaks me out! I can't look at it for more than a few seconds!
Lol. I figured the motor boat belonged on a boat forum.
Old 10-27-2013, 11:00 PM
Bouyhead's Avatar
Anyone want to buy a ZR6 cheap? I've been fighting this thing all weekend. I have good clearance underneath and shaft angle is real close. Many hurdles to jump yet but the front mounts have me concerned. I'm running an inch and a half spacer plate under the front mount and still have to crank the front mount all the way up. Having the mount cranked all the way up on the stud is not as stable as having it halfway as you see on most boats. If I run them that high i'll have problems down the road. Not sure how much higher I could or would want to go.
Anyone have any ideas? If I can talk DIM into exchanging it for the 300 hp 5.0 liter I might do it. Other commitments and the weather have me running out of time. Boat doesn't fit in the garage and working outside gets old real quick when the weather turns.
Old 10-27-2013, 11:04 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
Add another spacers under the front mounts..
/spôrk/
Old 10-27-2013, 11:44 PM
Ben Ben is offline
Boat: '94 PS205 LT1
Agree on higher mounts. You may want to consider an extra plate on the side of the mount to drop down and screw into the side of the area below the mount. This would help with lateral support for a really tall mount
Or, skip that. Not sure how much lateral force the motor sees. Seems like normal is torsional due to spinning the prop. This would seem to result in one mount (left one I think) being in tension and the other in compression.
How are the rear mounts looking?
Another option would be to see if there is a mount that slides into the engine with a "drop" to it. This would result in the eyelet being say two inches below the round part that slides to the engine.
Another option would be a rework or modification of there the mount connects to the engine. Pics of this?
