Old 10-21-2013, 09:27 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
Originally Posted by bochnak View Post
James, the gauge pegs full hot when wire is grounded. Reads full cold when disconnected.
Oops, I wrote it wrong, your gauge and wiring seems to be working correctly.
/spôrk/
Old 10-22-2013, 11:20 AM
bochnak bochnak is offline
Boat: 94' Prostar 205 - Indmar 5.7 TBI
I tested the sending unit yesterday and found it to be good:
Temp °F / Ohms
55 / 1500
75 / 775
120 / 210
170 / 95
190 / 53
The issue I'm having is the temp gauge reads 120, maybe 130 with a new 142/143 t-stat. Disconnecting the wire it reads 120, while grounding reads 240. I have various resistors ranging from 80-150, so I'll run the gauge through those and compare to sender values to see if it is the gauge.
I also have an IR gun to point at motor but that will have to wait until spring.
-Matt
Old 11-11-2013, 12:46 PM
Temp °F / Ohms
55 / 1500
75 / 775
120 / 210
170 / 95
190 / 53
I tested the gauge by grounding the tan wire through a 100 ohm resistor and gauge displayed about 130 or so. Same result at back of gauge. Time for a new gauge.
-Matt
Old 06-30-2014, 09:00 AM
Gauge and sender I bought:
http://www.oempartsllc.com/gaugetele...w-1-1-1-1.aspx
http://www.skidim.com/prodinfo.asp?number=R020003
-Matt
