Old 10-21-2013, 11:13 AM
bochnak bochnak is offline
Boat: 94' Prostar 205 - Indmar 5.7 TBI
Temp gauge sender resistance
Anyone have the temp gauge sender resistance values handy?
I found this:
http://www.jamestowndistributors.com...t.do?docId=842
75°F - 600-800 ohms
212°F - 55 ohms
Does anyone else have more values, maybe at 140°F? Maybe I can assume if would be around 325 or so ohms?
-Matt
Old 10-21-2013, 12:28 PM
Clymer's has
212 - 177
158 - 467
104 - 1800
68 - 3520
Old 10-21-2013, 12:34 PM
Clymer's has
212 - 177
158 - 467
104 - 1800
68 - 3520
Thanks Mike. I think those values might be for the ETS sensor for the ECM. I'm looking for the values for the CTS that the gauge reads.
When I disconnect and ground the tan wire from sender from intake (0 ohms) I can get the gauge to peg to 240. Infinite resistance gives me no reading.
-Matt
Old 10-21-2013, 01:03 PM
I got a new one from WWW.SKIDIM.COM they will prolly have the values.
Old 10-21-2013, 03:32 PM
Clymer does not have these values? I want to buy that manual.
-Matt
Old 10-21-2013, 03:50 PM
Those are the ones I gave you.
Old 10-21-2013, 04:02 PM
OK, looks like they only cover the ECM one then?
-Matt
Old 10-21-2013, 04:03 PM
I bet that is correct.
Old 10-21-2013, 08:42 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
The coolant gauge should be a 33-240 ohm type. 33 full hot (grounded) 240 full cold.(disconnected)
/spôrk/
Old 10-21-2013, 09:18 PM
Originally Posted by [email protected] View Post
The coolant gauge should be a 33-240 ohm type. 33 full cold, 240 full hot.
James, the gauge pegs full hot when wire is grounded. Reads full cold when disconnected.
-Matt
