Old 10-21-2013, 01:28 PM
Jerseydave's Avatar
TT Hero
Just did mine, ran the engine until 160 degrees then drained block and manifolds.
Added 5 gals of purple West Marine anti-freeze and it came out purple at the exhaust.
3 gals is not enough IMHO.
I was njskier on here.
Old 10-21-2013, 02:25 PM
bochnak bochnak is offline
Boat: 94' Prostar 205 - Indmar 5.7 TBI
The big question is should I be concerned? I'm certain the engine is protected.
Should I care about water in mufflers?
-Matt
Old 10-21-2013, 02:36 PM
blackhawk's Avatar
Boat: 2006 X15 350 MCX
After I completely drained water from everything, including taking the hoses loose and emptying them, I drove around the block to shake out any leftover water. Then I just poured antifreeze in mine without running it. First, I filled up the discharge hose from the raw water impeller, so that the impeller would be full of AF. I then took the large hose loose from the thermostat housing and poured about 2-3/4 gallons into the hose. That is the point that it ran out of the thermostat housing, so you know that the block is filled. On my MCX the hoses that go to the exhaust manifolds are above the large hose on the thermostat housing, so I didn't get any AF in there. I tried to take off those hoses to put some AF in there, but they would not budge. I would have needed to cut them loose. But, I know that the exhaust manifolds are drained of water because it gushed out full stream when I drained them. It would be nice to have some AF in there for corrosion protection, but I hated to cut the hoses.
Bochnak - Take loose your large hose at the thermostat housing if AF runs out, you should be good. If not, pour some AF in the hose until it comes out the housing.
Old 10-21-2013, 03:08 PM
I pulled the temp sending unit out of manifold for testing and RV gushed out. I also pulled one exhaust plug since I was wondering where all 3 gallons went. RV came out as well.
So, right now I know the block is full and so is one side of exhaust.
The concern I have is that water is sitting in the mufflers. I don't think it will be an issue since it is 3-4" diameter and mostly empty at this point.
-Matt
Old 10-21-2013, 03:21 PM
Put the wheels back on the trailer and take it for a ride up a steep hill
Old 10-21-2013, 03:30 PM
Ha! It took 3 of us to push it into the garage up there! I'll jack it up as high as it will go and call it a day.
-Matt
Old 10-21-2013, 03:58 PM
or... you could get a couple o' more gallons and make a bucket like mine...
Old 10-21-2013, 04:36 PM
bsloop bsloop is offline
Boat: 91' MC 240sc
OP answer - it will usually take 4-5 gal to have it spiting out the exhaust.
You did fail to run it up to temp before adding the AF but it appears the solution got everywhere it needed to for a standard raw water cooled motor.
Put her to bed and dream of Spring......
Old 10-21-2013, 04:41 PM
Thanks. I don't see how running it up to temp will help distribution of fluid. The cold RV fluid will eventually close the t-stat. Also, I had the t-stat housing off and there is a bypass hole which dumps in intake and exhaust manifolds. The RV fluids that gushed out when I pulled the temp sending unit kind of proves this theory.
I'll take your advice and dream of spring
-Matt
Old 10-21-2013, 04:53 PM
willyt's Avatar
willyt willyt is offline
Boat: ER xstar
mike... how did you make that bucket??
