Old 10-27-2013, 10:01 AM
Originally Posted by djue View Post
Grounding the RCAs between the Wet Sounds EQ and amps almost completely silences the hum. Note that grounding the RCA between the source unit and wet sounds EQ does nothing. And of course disconnecting the clarion remote from the Big computer completely resolves the noise with RCAs grounded or not. For those that are interested, the noise is originating from the Ilmor 5.7 throttle position sensor. The same piezo type hum can be heard direct from the sensor area. The sensor evidently calibrates for 2 -3 seconds when the ignition is moved to start. Then shuts down until the engine is started. You can hear the noise through the stereo in those 3 seconds then it goes away until engine start. When I disconnect the TPS wires, the noise is gone.
It's weird that a TPS would cause any noise. Assuming the Ilmor is very similar to a GM/Indmar engine, the 2-3 second time window seems like it would be from the IAC or fuel pump relay (the pump primes for 3 seconds on a GM or Indmar engine). A TPS is just a potentiometer and isn't actually controlled by the ECM, it just receives a control voltage and returns what it will, based on its position, to tell the ECM what to do.
Good to see that you got rid of most of the noise.
Old 10-27-2013, 07:35 PM
djue djue is offline
Boat: X-30 2012
Is IAC "idle speed control." I am not 100% sure that the plug I disconnected is the TPS - I was making a guess. I also originally thought it was my fuel pump, but with the noise disappearing when unplugging the TPS/ISC ? I assume it's not the fuel pump .
Old 04-11-2015, 03:00 PM
Btye1 Btye1 is offline
Boat: 1997 Sea Ray 330 Sundancer
Did you ever really resolve this high pitched noise. I am doing a stereo in a guys 2012 x45 and am having the same issue. Have already put the head unit and wet sounds eq on the same power and ground as the amplifiers and put a relay in to bypass the ignition switch. Looking for some help here. Next step is going to be a ground loop isolator but wanted to check here first since this seems to be a mastercraft specific problem.
Old 04-11-2015, 03:47 PM
Did you feed the head unit's memory/main power from the cables as the amplifiers, or just isolate the switched wire? EVERYTHING to the head unit needs to come from the amplifier feed, including the ground. Loop the head unit's ground to the screw on the back (this should have a support strap on it, too) and connect a new ground wire to it. Run that new ground to the distribution block for the amplifiers' ground. DO NOT connect the ground wire from the dash- cut the terminal off and secure it to the harness, but don't use it unless you want to add some kind of accessory. The switched red wire in the dash- If that's latching a relay behind the head unit and you ran a new wire from the amplifiers, connect the head unit's yellow wire to the feed wire, ahead of the relay.
Using a ground loop isolator may screw up the sound- they're not all made well and sometimes, it sounds bad (decreases bass response). Seems unlikely, but I have heard it happen.
Are the audio cables bundled with wires that carry 12VDC? If so, move them away. If you want to find out if the noise is being induced, unplug the cables from the head unit's output jacks- if the noise continues but disappears when you touch the plugs (or short the tip to the ring), it may be induced. If the noise stops as soon as you unplug the cables from the amp, it's probably a ground loop.
What gauge is the power and ground cable going to the amplifier(s)? Isolate the audio system from all other circuits, meeting them only at the battery posts. Measure the voltage across the battery terminals and then repeat this at the amplifiers' + and - terminals with the system turned off. You should see no difference in voltage. If you do, find out why.
