Old 03-29-2015, 08:43 PM
TNX5TY TNX5TY is offline
Boat: 2013 X10
Amplifier getting no power.
While getting the boat prepared for this summer, I turn key to listen to some music after I had charged the battery back up to do some work in the shop and nothing from the four speakers on tower. I check and there is no power to my amplifier (no green light) haha. Cabin speakers and head unit are powered and running powered seperately. I decided it could be a bad ground on amp ground wires so I did some work on that hooked them back up,still nothing.
Thought perhaps it was the amp. Tried a different one. Same result.
Any thoughts as to what the heck is going on?
It has got to be my battery I am guessing? I bought a Duralast Deep Cycle from Autozone last summer. Put battery Tenderer to bring it back to full charge before I was tinkering with it.
Think its the battery?
2001 X5
If I am not in my office, i'm on the lake or in one of my deer stands.
Old 03-29-2015, 09:16 PM
MLA MLA is online now
Boat: pontoon
Did you test the battery with a volt meter? I would start with checking voltage across the amp power terminals with the volt meter. It will take all guessing out of the equation. Start with the meter's leads on the main B+ and B-, then move the B+ lead to the turn-on terminal. Should read battery voltage both times. Work back on which ever circuit is not reading battery voltage.
The head-unit and amp should be drawing from the same source.
Old 03-29-2015, 10:57 PM
Tommy1005 Tommy1005 is offline
Boat: None
Fuse on the power cable to the amp? I know that's a really simple idea, but stranger things have caused issues. Might also be fuses in the distribution block.
Old 03-30-2015, 09:17 AM
Boat: 2013 X10
Thanks for quick replies. I will try the following. I am going to pick up some 30A fuses and test it out again.
If those fail I hope Autozone backs up their 12 month replacement gurantee.
2001 X5
Old 03-30-2015, 09:29 AM
CheeseSteak1's Avatar
CheeseSteak1 CheeseSteak1 is offline
Boat: 2009 X30 MCX / 2003 X2 MCX
Wasn't aware Autozone sold amps. That might be your problem.
Old 03-30-2015, 05:37 PM
Boat: 2013 X10
Autozone Duralast Deep Cycle Battery ( if its battery)
2001 X5
Old 04-08-2015, 10:03 PM
Gteeiguy Gteeiguy is offline
Boat: 1992 Prostar 190 powerslot 351
Really sounds like your inline fuse.
Old 04-13-2015, 01:09 PM
Boat: 2013 X10
Sys Control wire from headunit to Amp was the culprit. Got it fixed nearly right after I posted for help. I was overthinking it and checked all wires and found it pretty quick.
I guess I am too quick to panic and hit up Teamtalk!
Thanks for input from everyone!
2001 X5
