Old 10-16-2013, 11:29 AM
Originally Posted by TRBenj View Post
Youre talking to the wrong people.
Theres no reason you cant have your cake and eat it too... assuming you'd consider a 60mph ski boat "fast". It just takes a little bit of knowledge and a little bit of money (well, maybe more than a little). Im in the camp that thinks "if it wasnt built for skiing, then I dont really care how fast it goes". Fast ski boats are pretty cool.
Done properly, a "fast" ski boat is more than just a thrill- it enhances skiing performance as well. Lighter parts = smaller wake, more power = better holeshot, better speed holding, more throttle response, higher top end... so better for barefooting, pulling larger ski acts, etc.
Nothing to argue with there.
Old 10-16-2013, 09:58 PM
Allstricker Allstricker is offline
Boat: Mastercraft, sportstar 190, 1999, 5.7lt vortec max
Whats ECM?
I just put a new prop and noticed a bit difference. 3 blade 11.5 13''.
Old 10-16-2013, 10:01 PM
Whats ECM?
I just upgraded my prop to a 3 blade 11.5 pitch 13'' and noticed a big difference in the boats performance.
Chris
Old 10-16-2013, 10:52 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
Originally Posted by Allstricker View Post
Whats ECM?
Chris
Engine Control Module, its the brain that controls the engine and fuel injection.
/spôrk/
Old 10-17-2013, 08:49 PM
Is there a benefit in changing the ECM out to a higher performance one?
Chris
Old 10-17-2013, 08:54 PM
Spork's Avatar
Boat: Sporkcraft
Chris
Only if you change out engine components such as cylinders heads, rocker arms, intake manifolds, throttle bodies, camshafts etc.
I ask again, what are your performance goals? What is your current top end mph speed and at what engine rpm?
/spôrk/
Old 10-17-2013, 11:39 PM
plus you will need a new transmission if you pass the specs on your current trans.
Old 10-17-2013, 11:50 PM
bhanson bhanson is offline
Boat: 2001 X-30 "Surf Edition", LTR, 2079 prop, FAE, straight silencers, 3000# ballast, custom platform, manual surf fin, 1050 Hours and counting
There is no magic pixie dust. Your motor will perform as designed unless there is something impeding performance. If you want to increase performance, then you have to do engine mods: heads, cam, cylinders, etc. If you want to maximize performance of your current setup then clean the fuel delivery (carb, EFI), make sure plugs/wires are good, timing/ECM are right, all the little things can add up performance-wise. Also, find a convenient place to buy non-ethanol fuel !
Old 10-19-2013, 12:29 PM
4400rpm 43 mile per hour.
Old 10-19-2013, 12:35 PM
snork snork is offline
Boat: 07 xstar
With the correct prop that shouldn't be a problem
