Old 10-15-2013, 10:30 AM
Jaxon4's Avatar
Jaxon4 Jaxon4 is offline
Boat: 1989 Tristar 190
Over-heating on Tristar 190
I think I have a bad raw water impeller..I over-heated to like 210-220 degrees last night for a long time before I could get it cooled down to like 150..I have a good stream of water coming from behind the impeller between the water pump and impeller??!! Any thoughts on the fix of the impeller or could it be the water pump or both?? Is the impeller an easy fix???!!
Old 10-15-2013, 11:30 AM
Impeller should be changed every season. impeller is easy - is water pump leaking at all? Have you inspected the impeller?
Old 10-15-2013, 11:32 AM
Do you have a water leak from the raw water pump? Pictures are very helpful here.
Old 10-15-2013, 12:22 PM
madcityskier's Avatar
x2 for pictures. The impeller is inside the water pump. Do you mean the gasket is leaking? My best guess at the moment is that you might have leaking hose, but that's a pretty wild guess.
Old 10-15-2013, 01:37 PM
Jaxon4's Avatar
I have not inspected the impeller...what am I looking for inside ???
Old 10-15-2013, 01:39 PM
Jaxon4's Avatar
is the raw water pump the brass plate with the 5 bolts right up front in front of the pump??
Old 10-15-2013, 02:38 PM
Jaxon4's Avatar
Its leaking from behind and under the raw water pump!!! Easy fix?? Any suggestions??!!
Old 10-15-2013, 02:39 PM
Jaxon4's Avatar
Yes!!! For sure!! Easy fix??
Old 10-15-2013, 02:40 PM
Jaxon4's Avatar
Yes!! For sure from the raw water pump!!
Old 10-15-2013, 04:20 PM
More specifically, what part of the pump is it leaking from the shaft, a hose, the cover plate, a crack in the housing...
The nature of the leak is the problem here. It's probably a pretty easy fix, but saying the water pump is leaking is like asking how much is a bottle of wine. To get an answer more specific information is required.
