Old 08-31-2017, 09:05 AM
pmcski pmcski is offline
Boat: 2016 MasterCraft Prostar
Winterizing Heater in a Prostar
I have a 2016 Prostar and wondering if anyone has had any experience winterizing the heater. This will be the first year I will be doing it and looking for some guidance/suggestions for doing it. Thanks in advance!
Old 08-31-2017, 09:12 AM
captain planet's Avatar
captain planet captain planet is offline
Boat: 2003 PS197, MCX, Powerslot
Unhook both hoses from the engine. Put a funnel in one hose and pour antifreeze through it until it comes out the other hose. This may require you to help it through the heater coil with a little light pressure. Reconnect both hoses to the engine and close the valve that sends water through them. Then run antifreeze through your block.
2003 ProStar 197, MCX and Powerslot.
RON PAUL FOR PRESIDENT[/size]
"Don't steal. The government hates competition." - Ron Paul
Old 08-31-2017, 11:14 PM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
I blow my out, first with lung pressure which is easy at first, and then with the air gun on my compressor. Then I leave it open to the air. Never had a problem in 8 years in -30 degree temps.
Old 09-01-2017, 09:04 AM
MattsCraft's Avatar
Same concept as dry block - Certainly works - I do both, blow out water, blow through anti-freeze Hook it back up after
Old 09-27-2017, 03:48 PM
Thanks guys. Where would the hoses be located on the engine?
Old 09-27-2017, 04:43 PM
I don't know how they do it on the new prostar engines, but on my 98 there was a valve above the thermostat housing to be able to turn off the water flow to the heater core that you disconnect and the other end was near the thermostat housing. Disconnect both ends and add antifreeze as I described.
Old 09-27-2017, 09:49 PM
wheelerd's Avatar
Boat: 2005 X2
Some also have the return line going into the draw side of the water pump. And then . . . some of us have inserted a Y into the raw water inlet hose to help improve circulation at low rpm's.
Old 09-28-2017, 01:31 AM
2010Prostar197's Avatar
2010Prostar197 2010Prostar197 is offline
Boat: 2010 Prostar 197
Disconnect both hoses and use a shop vac to suck the water out....then drop the open hose into a gallon container of rv antifreeze and let the shop vac empty the gallon of antifreeze.
Anything left in the heater is pure antifreeze now.
Hook the hoses back up and hope spring comes soon!!
winterization
