Old 10-13-2013, 05:09 PM
270BBR 270BBR is offline
Boat: 1989 Mastercraft Tristar 190 351
Remove steering wheel on a Tristar.
I need to remove the steering wheel on my 1989 Master Craft Tristar 190, does the centre of the steering wheel pop off, remove a nut and use a puller? or is there some other way.
Old 10-13-2013, 05:39 PM
Tristarboarder's Avatar
Boat: 2002 Xstar
Super easy. Simply and carefully pry the center cap out of the center of the wheel. Under that are 3 bolts. Remove those. Then there is a nut on a splined shaft. Take off that nut. Pull off wheel. No puller or any other tool needed.
Old 10-13-2013, 05:40 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
1, remove center cap with a hook or small screwdriver, pull straight aft, 2, then there is a large nut and 3 smaller bolts, remove all 4 then steering wheel will come straight off. No need for a puller its not splined on our models.
/spôrk/
Old 10-13-2013, 08:39 PM
abburns abburns is offline
Boat: 1990 Tristar190
no need to remove the three small bolts under the center cap. Just remove the big nut on the splined shaft....I just removed the steering wheel yesterday.
Old 10-14-2013, 05:37 PM
Thanks
Thanks
