Old 10-08-2013, 11:56 PM
Topp dawg Topp dawg is offline
Boat: 2003 Mastercraft X10
Replaced mmdc and still nothing.
Today I replaced my mmdc on my 2003 x10 and my gauges still don't work. I bought a new mmdc from medallion and my gauges still don't function at all. The plugs all have power and ground that go to each gauge. I even tried only plugging one gauge in at a time. I checked all fuses and wires I can't figure out what the issue is. The boat starts and runs but I do have a check engine light on. Anyone have any ideas or tips I can try.
Old 10-09-2013, 01:02 AM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
If the light is on, then there is probably a code being thrown. You could get that checked at a dealer and go from there. Have you tried replacing a gauge? I wouldn't think that would be the issue, but just a thought. Where in the SE are you?
Old 10-09-2013, 08:24 AM
I am located in Niceville FL. So far i am unable to locate a local dealer that has a computer that would read the code. The closest dealer i could find was near Birmingham.
Old 10-09-2013, 03:18 PM
I have read many times though that the check engine light would not cause the gauges to not function.
Old 10-09-2013, 09:42 PM
I called medallion multiple times today and they have the worst customer service in the world. I asked them for a troubleshooting guide and they emailed me a picture of an mmdc. I called them back multiple times and they won't return my calls. I will keep calling tomorrow.
Old 10-11-2013, 10:19 AM
I finally got a troubleshooting guide from medallion and I took a volt meter and started testing wires. It turns out my original MMDC is good. I will be sending the new MMDC back for a refund. I have narrowed down the issue somewhat.
The correct volts are going into the MMDC and out of the MMDC but the 4 wire plugs that go into the back of each gauge is not receiving the correct volts. I think this means that the issue lies in the wire harness between the gauges and MMDC. I have checked the 3 fuzes i could find and they are good, i can't find any broken wires. I am confused on whats going on.
Anyone have any advice for me?
Old 10-11-2013, 12:49 PM
I just spoke with medallion again and they told me to unplug my Perfectpass and re-test all the wires. I don't see how this is related since my perfect pass is working fine and hasn't changed at all.
They also said the speedo calibration buttons are tied to the MMDC. I will be checking that switch tonight to test for a bad breaker.
Old 11-12-2013, 09:19 PM
I ordered new gauges from Medallion and installed them. Everything functions as normal. I still have a check engine light on so I will be taking it to the dealer at some point but at least my gauge issues are over.
Old 11-12-2013, 09:53 PM
What is the resistance from the MDC ground to the battery negative post. Not the cable clamp, the post.
Old 11-13-2013, 10:10 AM
Boat: No Boat
Every single gauge in your boat went bad at the same time?
Tim
