Trickle charge, tender or nothing to batterys
What do you guys do. Amazing how much difference of opinions there is on this stuff
I have a guest 2611a charger installed on the boat. I just leave it plugged in when I'm not using the boat. It was about $100.
Battery tender jr. just plug in the quick disconnect when your done, $40
/spôrk/ a spoon-shaped eating utensil with short tines at the tip |
Step up to an installed charger like Guest /Marinco and maintain your batteries properly though out the entire year.
Another option either installed or mobile is the CTEK 7002 or others in their line. http://smartercharger.com/battery-chargers/ More advanced charging and desulfation capabilities. Battery Tender / trickle chargers are old technology and low power. Batteries are a big investment and while something is better than nothing, there are better products that can significantly increase battery life.
1991 MariStar 240sc, 454, tower, WetSounds, Krypt and Rockford Fosgate |
Don't use a trickle charger unless you plan on monitoring it daily. Trickle chargers don't ever turn off. Get a charger that goes into float mode (stops charging and monitors voltage). Battery tender = connect it and forget it... until spring.
Jeff |
#7
OH-IO! |
#8
#9
I installed a ProMariner ProSport onboard charger in my last boat - loved it. Took out that anxiety of having a dead battery on the ramp or out in the lake.
http://www.amazon.com/ProMariner-Pro...rds=promariner |
#10
If you live in a cold climate I would remove the battery from the boat after you winterize the boat and keep the battery in your basement with a Battery Tender Plus on it. I did this since the boat was bought new and my factory battery lasted 9 years
This is the one that I have used on my Boat, Jet Ski's, Motorcycle, and cars : http://batterytender.com/battery-ten...-at-1-25a.html
2003 Prostar 209 MCX |
Thread Tools | |
Display Modes | |
