Old 10-03-2013, 08:11 PM
h20ski454 h20ski454 is offline
Boat: 1989 Barefoot 190, 454
Grease Zerc Fitting on Steering Cable
Folks:
I have an 89 MasterCraft and need to grease the steering cable. The issue is there is no grease zerc fitting in the aluminum housing. There is a whole where it appears there should be a fitting.
I have tried every possible size of zerc fittings but nothing fits into the threads.
Should there be a zerc fitting there?
If so what size?
If no zerc fitting how does one go about greasing the cable?
thanks
H20Ski454....
Old 10-03-2013, 09:25 PM
AZDave's Avatar
AZDave AZDave is offline
Boat: 1993 Stars & Stripes Prostar 190 351 285 hp
I drilled mine out, vacuuming as I went, and and screwed in a larger size zerk. 5 years no issues. Origional fitting cannot be found.
Old 10-03-2013, 09:32 PM
Skir68 Skir68 is offline
Boat: MasterCraft, '83 S&S Powerslot, Red Metalflake!
mine busted out this spring when I went to grease it up. it stuck in the grease gun. Drill it out and put in the next size bigger.
Old 10-11-2013, 06:55 AM
Thanks for the responses. Do you take the cable out before drilling or am I over thinking? Also I have read that there should not be a ball\stopper in the zerc fitting so there is a way to release any pressure, does that still hold true?
thanks..........
Old 10-11-2013, 07:09 AM
Table Rocker's Avatar
How about using a needle on your grease gun.
'96 ProStar 205 SD LT-1
Old 10-11-2013, 04:39 PM
Boat: 1987 ProStar 190
Here is the fitting on my '87.
Just cover your drill bit in grease, it'll catch the shavings. Then cover the tap in grease as well, to catch the shavings. Also remove the check valve from the new zerk and you're done!
