  #41
Old 10-10-2013, 10:15 AM
broncotw's Avatar
broncotw broncotw is offline
Boat: 2010 MasterCraft Prostar 190 TT, Indmar MCX GM 350
Wow that's a nice boat! Congrats!
Ted W
Hook Em' Horns
Old 10-10-2013, 11:03 AM
DooSPX's Avatar
DooSPX DooSPX is offline
Beautiful boat! Congratulations! Its like the OB younger brother of my boat. Same color scheme!
A.K.A. One of a kind mistake
2011 Best In Show- 1987-2000 class
Trying to keep slalom alive
Need a new prop to fit your needs? Call Eric from OJ PROPS 800-359-9730
Old 10-10-2013, 11:20 AM
Waterskibum Waterskibum is offline
Boat: 93 S&S 190
Damn! Only 190 hours? Not even broken in yet Very nice score!
Old 10-21-2013, 11:50 AM
cbryan70's Avatar
cbryan70 cbryan70 is offline
Boat: 1993 Prostar 205
Going to dig into the boat this afternoon hopfully. Stern Light is not working and the Horn does not work. What are the steps to testing. I have a ohm meter thing that I can never get the correct setting on to test voltage. What should it be set at?
Old 10-21-2013, 12:04 PM
Set it for 20 volts. If you have an auto-ranging voltmeter you may not need to make adjustments. Picture of said meter will help.
With the stern light removed from the socket, turn the running lights on and connect probed to the two pins. If you show battery voltage, check your bulb. If no voltage check your fuse.
For testing horn, check your fuse first. Next disconnect horn connectors and insert voltmeter leads. Push horn button and look for battery voltage. If nothing, remove wires from switch and connect to each other. If battery voltage is present your switch is bad. Reconnect horn wires and test horn by connecting switch wires to confirm forn operation.
Old 05-27-2014, 01:37 PM
bochnak bochnak is offline
Boat: 94' Prostar 205 - Indmar 5.7 TBI
That is a sweet boat!
-Matt
Old 05-27-2014, 01:53 PM
cbryan70's Avatar
Thank you, it was in great shape but needed a really good cleaning.
Amazing the list of things to do to make it what you want.
Added swing away
added bimini top
added a radio 4 speakers amp and sub
redid the brakes
got new tires
added rollers to the prop guard.
Did some rewiring of the dash to get the voltage correct.
Next up is fixing the fuel sending unit. then...fingers crossed I will be done
Old 05-27-2014, 01:56 PM
Pfffff....not as a boat owner. J/K good luck.
-Matt
Old 05-27-2014, 01:57 PM
cbryan70's Avatar
Ha I hear ya. I keep dreaming of PP but its just soo expensive
Old 05-27-2014, 05:34 PM
Ski-me's Avatar
Ski-me Ski-me is offline
Yea, but find a way. That was a GREAT addition to my boat. I found a used PP module and then bought the servo and gauge new. Mine is only RPM based for slalom so no need for the paddlewheel, etc. Worth considering!
- Jeff
1994 205, LT1
