Old 09-28-2013, 02:25 AM
nullpointer's Avatar
nullpointer nullpointer is offline
Boat: 2013 X-2
2013 X2 Hour Meter
It seems like my 2013 X2 counts hours anytime the touchscreen is on (the key is in the ignition position but the engine is off). Is this normal? My better half likes to keep the touch screen on because the depth finder makes her more comfortable if we are just hanging out without an anchor. We also find that when switching riders we keep it on so that we don't have to reset any of the profile settings or screens.
My fear is that this will kill my resale value. We are currently showing almost 40 hours on a boat we have had for 2 months. I think the engine most likely only has 20 hours on it (at max). I also worry that I might have done my initial oil change a little early since I wasn't aware it was counting hours when the engine wasn't on.
So I guess I can stop rambling and just ask my questions :-)
- Does the 2013's touchscreen actually count engine hours even if the engine is off?
- If so, I assume the engine computer stores only the actual hours on the engine. Is this correct?
- If so, can a dealer sync the touchscreen hours with the engine hours at time of resale so it is an accurate representation of the use of the boat?
- Or is it stupid to keep the touchscreen on when not moving?
Thanks again for everyone's insight!
Old 09-28-2013, 10:05 AM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
The hour meter on the dash does count the hours anytime the ignition is in the ON position regardless of engine condition, the ECM will log actual engine run hours and the dealer is able to access this with their scantool to read. I don't believe the dash and ecm can be synced.
If resale hours is your concern you can have a dealer do a DIACOM service report and this will list all hours that was engine run and at what rpm's they were run at.
I too am concerned about depth levels while floating, what we do is just turn on ignition every so often to check the depth, that way it keeps the hours off the meter.
/spôrk/
Old 09-28-2013, 10:27 AM
501s's Avatar
501s 501s is offline
Boat: 2013 X-30, 6.0L, 2500lbs of Ballast, 650lbs of Lead.
On my 2013, the hours only count up if the engine is running.
2013 X-30, 6.0L with 2500lbs of ballast and 500 lbs of lead.
Old 09-28-2013, 12:48 PM
bamabonners's Avatar
bamabonners bamabonners is offline
Boat: 2011 ps 197 wtt, 2013 X2 (previous)
i believe my 2013 only counts when the engine is running.
Old 09-29-2013, 11:40 AM
MattsCraft's Avatar
^^^ Same here
Old 09-29-2013, 11:54 AM
Mastercraft13's Avatar
Boat: 2013 X-10 6.0
Same here, I actually looked at it to see if it had changed yesterday when we were parked for an hour or so.
Old 09-29-2013, 01:26 PM
scott023's Avatar
scott023 scott023 is offline
Boat: 2008 X45 Switch L18
It should only count when engine is running. Should not count in accessory mode.
Old 09-29-2013, 08:39 PM
Boat: 2013 X-2
Thanks everyone! I will pay more attention next weekend and see if I can confirm one way or another. It is possible that I am just using the boat a lot more than I thought.
Thanks again!
Josh
Old 09-29-2013, 09:28 PM
Spork's Avatar
Boat: Sporkcraft
Could possibly be a difference in the medallion system and the new murphy systems.
/spôrk/
Old 09-29-2013, 10:26 PM
501s's Avatar
I've had both systems, and neither counted hours with the engine off.
2013, touchscreen, x-2
