Old 10-21-2005, 02:09 PM
wakescene's Avatar
wakescene wakescene is offline
Boat: 2001 Maristar 210VRS, LTR 330HP, ZeroFlex Tower, KGB Ballast, PerfectPass Wakeboard Pro,
Winterization - Antifreeze Question...please help!
Hi all,
I am getting ready to winterize my 2001 MC 210VRS. My question involves the Antifreeze.
Currently we are talking about a 2001 210VRS. I have the LTR motor with Closed Cooling.
I understand that the RV Antifreeze is not recommended for the Aluminum heads on my motor, and I would not be putting this into the motor as it already has Closed Cooling right now, with a mixture that is good for -25degrees (tested this last night).
Can I use the RV Antifreeze for the raw water system?
- OR -
Because I have a Closed Cooling system, can I jsut drain and blow out the raw water system and leave it at that?
Any advice is appreciated.
Thanks,
KG
Old 10-21-2005, 03:18 PM
peason's Avatar
peason peason is offline
Boat: MC, 209, 2002, 310 HP
I would think you just need to drain the fresh water system and that should be it. I doubt you need to mess with the closed system. What does the owner's manual say?
Old 10-21-2005, 03:27 PM
Tom023 Tom023 is offline
Boat: 2001 X30 LTR
If you have an LTR you don't have aluminum heads. Is it the LT-1?
2001 X30 LTR
